Choosing the right size tire
http://www.rims-n-tires.com/info_specs.jsp
Above is a link you can use. All you need to do it put your stock tire info and insert the new tire you want to go with and it will give you in detial all the specs. Such as Over all Diameter. If you tires will be larger or smaller then stock.
Its a accurate chart. I've been using it for a while.. so I thought I would share with everyone else. This can help you Determine what tire size yous hould get when purchaing new wheels.
It also allows you to play with offsets.. But I also have another tutorial on choose offsets so please search for that.
Enjoy....
Enjoy....
- indiglosolara
- Solara 2 xB
