SolaraGuy.com • View topic - How to disable your DRL (the right way)
Postby Skew » Sat Nov 28, 2009 1:17 am
It's in the upper left hand part of the engine bay.
After that, just unplug the dash sensor, and you are set.
Skew
Postby Ruski » Sat Nov 28, 2009 7:23 am
Skew wrote:It's in the upper left hand part of the engine bay.
Does Not always Work
Postby tru3aznplayaz » Sat Nov 28, 2009 6:41 pm
ok thanks..nice engine bay by the way..
tru3aznplayaz
Postby Skew » Thu Dec 03, 2009 8:23 pm
It should work every time if you unplug the dash sensor.
Skew
Postby hecarmaldonado » Wed Apr 28, 2010 8:32 am
will you have cel after unpluging
hecarmaldonado
Postby Ruski » Wed Apr 28, 2010 8:43 am
Cel has nothing to do with DRL
Postby hecarmaldonado » Wed Apr 28, 2010 9:17 am
^ i'm just asking if your check engine light or any error codes come up when unplugging this. remember every time your vehicle gets turned on the computer checks everything to make sure everything is running and working so by removing this no warning lights come on?
hecarmaldonado
Postby TheMack » Wed Apr 28, 2010 2:39 pm
no warnings came on for me
TheMack
Re: How to disable your DRL (the right way)
Postby demo4o1 » Fri Feb 03, 2012 7:23 pm
just an update and MY opinion.. when u unplug the gray plug it will disable the 24/7 day time running. but WILL come back on at dawn which i dont mind. but i think ima still cut the red/blue wire in the morning just so i can run my HID fogs without turning on the head lights
99 SE, 20" toyota venza rims. hidheadlights/fogs LED reverse light, plate light, dome, reverse gauge, DTR mod fog light mod, fresh paint
demo4o1
Postby demo4o1 » Fri Feb 10, 2012 9:51 am
also if u wanna run JUST ur fogs at night. just put it on high beam. head lights will go out unless u have hi/low HIDS but this will only work with the fog rely mod
demo4o1
Postby 2Gud2BTru » Thu Jun 21, 2012 10:39 am
Okay so after reading through this entire post and searching through the website, Im just a little confused on how to unplug the grey plug in the top left if the engine bay like Ruski said. Do I unplug the inside plug behind the metal plate that says "Hot, No hands" or is it the plug before that nearest to where the strut and springs are? And how do I unplug? Im having troubles figuring out how to unplug it. And then i read about the night time sensor on the passenger side, how do i pop it up to unplug that too? Thanks for the help! Much appreciated.
-01' SLE v6 coupe:Traded in. 223k
-06' Accord Coupe 4banger: DD
2Gud2BTru
Postby dinoxor » Thu Jun 21, 2012 11:35 am
Here. Hopefully this will end the six year old thread.
For my car you will need to:
1. Unplug that grey plug
2. Inside the dash there's this dome thing sitting on the passenger side near the windshield.
You will need a flathead to pry the base up and disconnect the sensor
Tada! As simple as pie
dinoxor
Postby 2Gud2BTru » Thu Jun 21, 2012 12:03 pm
Wow, thanks alot! Wish it was posted like that before. I will definitely do that like now.
2Gud2BTru
Users browsing this forum: Google [Bot] and 3 guests
