SolaraGuy.com • View topic - How to reverse the polarity(positive/negative) for 9005/9006
Postby Ruski » Mon Oct 29, 2007 6:52 pm
Step 1
Find the female connector
for the 9005/9006 wire
harness.
Step 2
Find a pin or needle tool
with a sharp tip.
Step 3
With the sharp tip tool,
gentle push on the lever
that is holding the RED
wire prong.
How to reverse the polarity(positive/negative) for 9005/9006 HID Kit.
lever
Step 4
After gently push on the lever with the sharp tip tool,
simply pull the prong out from the connector. Repeat
Step 2 and Step 3 for the BLACK wire
Step 5
When both Red and Black wires are removed from the
connector, reverse their position and insert the wires
back in to the connector.
After:Image
Before:Image
Step 6
Repeat Step 1 to Step 5 for the other wire harness,
and simply follow the installation guide (included in
the kit) to install your 9005/9006 HID kit.
Postby funboy102 » Mon Oct 29, 2007 7:59 pm
Can anyone tell me if this method of fixing is kit-specific or car-specific? This is because I have an HID kit that is working on an older car (93 Camry) but not a newer car (a 05 tC or a 03 Camry). I was wondering if this fix would make it work on the newer cars.
Good write-up!
funboy102
Postby Ruski » Mon Oct 29, 2007 8:04 pm
go look at your harness from your car camry or Tc, i bet the colors dont match up when you plug the harness in. its probably red-black and black- red which was my case
it needs to be red-red and black-black
Users browsing this forum: No registered users and 89 guests
