SolaraGuy.com • View topic - center dash
center dash
center dash
Postby EDuB777 » Thu Jan 24, 2008 8:26 pm
Hey guys, im planning on doing some stereo work, how do i take off the center dash peace, surrouding the ac and stereo?
EDuB777
Postby Jakecallun20 » Thu Jan 24, 2008 8:28 pm
Postby EDuB777 » Thu Jan 24, 2008 8:41 pm
i know ive seen it somewhere how to do it, but i cant find it anymore on the search
EDuB777
Postby woa_its_j3ff » Thu Jan 24, 2008 8:44 pm
flat head screwdriver, pry it out from the top between the black piece and the tan/gray piece.. it should pop out. remove the 2 clips, one for hazard light I think, another one for clock..
then pull out.
Postby nemoxfishy » Thu Jan 24, 2008 8:55 pm
easiest way is to pull out the ashtray.... and slide your hand inside a bit and PULL .... its just a lil trim piece then slowly move your way up... i think i've taken that thing apart 100 times.... u might want to move your shifter down b/c its kinda in the way....
nemoxfishy
Postby EDuB777 » Thu Jan 24, 2008 8:58 pm
alright, thanks guys
EDuB777
Postby BlKSo|aRa » Thu Jan 24, 2008 10:12 pm
nemoxfishy wrote:easiest way is to pull out the ashtray.... and slide your hand inside a bit and PULL .... its just a lil trim piece then slowly move your way up... i think i've taken that thing apart 100 times.... u might want to move your shifter down b/c its kinda in the way....
pull where? to which direction?
BlKSo|aRa
Postby AllShowNoGo » Thu Jan 24, 2008 10:17 pm
^^^Pull towards yourself
AllShowNoGo
Postby Ransom8707 » Thu Jan 24, 2008 10:18 pm
I would suggest just unscrewing than to PULL if this is your first time taking it apart. I would write a tutorial but im kinda sleepy right now :-?
Ransom8707
Postby DrLove » Fri Jan 25, 2008 6:28 am
nemoxfishy said right, remove ashtray, pull the piece, and if your car is auto, put the car on gear 1 or 2. Unplug the wire in the bottom (cig,ashtray light,..) and turn the piece over your sterring, this way you can work without unplug all the wire of the center dash bezel. I did it 20 times for my little LED mod, new radio,etc...
Mazda 6 2010 6 speed black GS
DrLove
Postby Jakecallun20 » Fri Jan 25, 2008 11:13 am
I find it helpful to remove the trim piece around the shifter, unplug the 12V plug and remove it. Then pull out ashtray, and ciggerette lighter. then grab hold of the bottom piece around where the ash tray sat and pull it up carefully. Then take your finger DO NOT USE A SCREWDRIVER (If you have the wood trim) and kinda pop it off. There are no screws here, it is all clips. Very easy to do. Just unplug the clock/hazards at the top end of the console and voila.
Postby EDuB777 » Fri Jan 25, 2008 12:36 pm
to remove the cigarette and clock wired do you take of the dash then remove the wire connections from the rear, or do you do something on top then remove the dash?
EDuB777
