SolaraGuy.com • View topic - Walbro Fuel Pump Installation DIY
Postby ASG14 » Wed Jul 22, 2009 10:43 am
Big thanks to Vik (Dawgz) for helping with the install and the DIY here. J
1: Unscrew gas cap to relieve pressure in the fuel system.
2: Remove the rear seat bottom. Simply pull the seat up. It’s just held down by 2 grip tabs.
3: Pull up the metal shield. It’s just attached with sticky stuff. Make sure not to get any on the carpet or seats.
4: Unplug the electrical connector.
5: Unscrew the 2 8mm screws that hold the shield over the fuel line.
6: Remove the fuel line by holding in the 2 clips and gently pulling the line.
7: Pull out the fuel pump assembly and have a bucket to put it in, so that gas doesn’t leak all over the interior.
8: Take off the bottom white cap holding the fuel pump in.
9: Remove the white rectangle piece with the wires and metal rod.
10: Remove the main black fuel pump and housing, and unclip the harness.
11: Cut the OEM connector off, then crimp the connector that came with the aftermarket fuel pump back on.
12: Remove the 4 outside tabs on the fuel pump.
13: Assemble the fuel pump. Put on the filter and attach the metal O-ring to secure it. Then put o-rings (need to get at the hardware store) over the fuel pump outlet, and place the OEM O-ring on the top.
14: Slide the fuel pump into the main black housing, then plug in the connector. Next, slide in the fuel pump onto the assembly, and push back on the black housing.
15: Cut out the top center of the bottom white cap that holts the fuel pump on.
16: Put back on the white rectangle piece with the wires and metal rod.
17: Put back in the fuel pump assembly into the car. It is a SLIGHT bit longer then the OEM one was, so it is a bit tricky to screw down. This is normal, so don’t be worried. It takes a while to get it screwed down the 1st time.
17A: Place the round black bracket over the fuel pump assembly.
17B: Connect the fuel hose by simply sliding it onto the clips. Do NOT force it on. If it doesn’t go right on, the clip is in the wrong position.
17C: Place the smaller black cover back on.
17D: Screw the 8mm bolts back on in a criss cross pattern and torque to 35 in/lbs.
18: Plug the connector back in and put back on the cover.
19: Put back in seat.
ASG14
Postby Ilovemylara » Wed Jul 22, 2009 11:10 am
Nice tutorial Adam! Thanks, I was actually looking for this, to install mine.
Postby Dawgz » Wed Jul 22, 2009 11:13 am
the pics came out nice.
If anything, the way to "modify" the fuel pump itself is the key to this whole install.
Postby SdeA » Wed Jul 22, 2009 11:24 am
Nice tutorial. Thanks for taking the pics step by step.
SdeA
Postby SleeperSolara » Wed Jul 22, 2009 11:58 am
Nice tutorial man. 8)
Postby carstenmeiner » Wed Jul 22, 2009 1:23 pm
Nice DIY :D
Did you buy the pump on Ebay ? Is it a 190 L/Hr Walbro ?
Do you remember the size on the O-rings ?
carstenmeiner
Postby lilm » Wed Jul 22, 2009 1:27 pm
sweet write up thanks
lilm
Postby Solarizona » Wed Jul 22, 2009 2:36 pm
Wow, nice write up. Very clear.
Solarizona
Postby ndeguzma » Wed Jul 22, 2009 3:01 pm
Funny you guys did this at the show!
ndeguzma
Postby akora12 » Wed Jul 22, 2009 3:12 pm
It's about time someone finally wrote this up. Nice work!
Postby Pogs » Thu Jul 23, 2009 3:36 am
nice ima need this real soon
Search and Win
Pogs
Postby 1gSE » Sat Jul 25, 2009 6:46 am
carstenmeiner wrote:Nice DIY :D
^^^ Yeah that. How long did it take? I might put the 255 in soon
Solara-M62 @ 5.5psi
1gSE
Postby Dawgz » Sat Jul 25, 2009 8:47 am
I'd say less than 30 mins?
Postby ArizonaEagle07 » Sat Jul 25, 2009 9:11 am
May I ask what benefits do you get with this Fuel Pump if any?
RIP: 2000 Toyota Solara SLE
ArizonaEagle07
Postby Dawgz » Sat Jul 25, 2009 9:20 am
ArizonaEagle07 wrote:May I ask what benefits do you get with this Fuel Pump if any?
on a N/A setup, its not needed.
but if ur sc'd, that 90lph oem pump isn't going to cut it, so you need this setup or a 255lph walbro.
Users browsing this forum: No registered users and 68 guests
