SolaraGuy.com • View topic - Adding Custom Center rear Tow Hook
Postby kenny6683 » Thu Sep 24, 2009 4:33 pm
You will need:
-Rear Towhook
-(2) 3/8 x 6" long bolt with nut and washer
-Door Striker thats a bit longer than this photo...
i think you can find one at any junkyard or auto stores should carry them (not sure i had one lying around)
Mine has this shape
-drill with 3/8 bit to make holes through trunk. This bit should be at least 3" long
In this photo you can see where i made the holes in the trunk...basically the location is right behind the paneling, but dont worry after this is complete your panel will go back like stock
The reason you notice there are an extra 2 holes next to the bolts is because when drilling through you can only get half way up from the bottom (under car)...then there is a gap. So i had to drill from the top as well (inside trunk) If you use a longer bit...about 6" long you might be able to go right up from under one shot
Notice where i placed the striker...basically is the beginning of the actual trunk and right after bumper support.
bolt became rusted because i cross threaded bolt so it may not be removed from outside anymore (too many thieves in NY)
I was only able to get one bolt into the striker but it holds nice and tight. Plus this mod is mostly for show as I never actually tested to see if it works.
finished product...you may have seen some red on tow hook...thats because i sprayed mine black : )
Image once again dont mind that dumb bumper light...it will be coming off soon
kenny6683
Postby Toy1mzfe » Thu Sep 24, 2009 5:00 pm
yo i want more pics of those g35 wheels.!
actually more pics of your whole car.
I like the idea of the tow hook, function or not.. keep assholes off your car.
Postby ToyoSolV6 » Thu Sep 24, 2009 5:26 pm
thanks bro! im going to get this done for sure. :)
Postby wkbrdr91 » Thu Sep 24, 2009 5:47 pm
whats the point in having it? One thing it is good for is the retards who dont know how big their car is and bump into you when parking behind you.. or getting rear ended at mcdonalds like i did in my truck... that guy has a nice little hole in his hood now :)
2006 Solara Sport
wkbrdr91
Postby SleeperSolara » Thu Sep 24, 2009 6:12 pm
Nice man. 8)
Postby kenny6683 » Fri Sep 25, 2009 7:12 am
the point of tow hooks is when your car has a kit and you dont want towing to ruin it if you ever get towed...but it really does protect the bumper from stupid people who cant park
kenny6683
Postby Dawgz » Fri Sep 25, 2009 9:46 am
wait, how can the tow truck tow ur car from the back, if ur FWD.....
i dont get the concept?
Postby Black Bob » Fri Sep 25, 2009 10:07 am
:think: I don't understand neither concept of what you guys are talking about. A TOW HOOK doesn't stick out far enough to prevent people from seeing it or even protecting you from damage--I think you guys are thinking TRAILER HITCH. And being most tow truck drivers' wet dream is jacking parked FWD cars from the rear for fun anyway, I don't wanna give them an advantage. I think I'd understand the idea more if the OP stated what the purpose of installing his rear tow hook.
Black Bob
Postby Pogs » Fri Sep 25, 2009 10:09 am
kenny6683 wrote:the point of tow hooks is when your car has a kit and you dont want towing to ruin it if you ever get towed...but it really does protect the bumper from stupid people who cant park
I trying to figure out what the hell you were talking about. Ofcourse Ive seen the bad parkers but nothing to worry about. Then I read your location: Queens ny
Search and Win
Pogs
Postby kenny6683 » Fri Sep 25, 2009 12:13 pm
you guys are right! FWD shouldnt be towed from the rear. I basically just did it for the look and here in Nyc cars park bumper to bumper. So if a car was very close to mine first thing they would touch is my tow hook. one more thing my solara is manual transmission...so as long as it is free from gears "neutral" you can tow from front or rear..correct me if i'm wrong
kenny6683
Postby ToyoSolV6 » Fri Sep 25, 2009 12:52 pm
cmon guys! quit bashing on this idea! its for looks only.
Postby Dawgz » Fri Sep 25, 2009 12:55 pm
Im not bashing on it, i think it looks pretty cool actually.
but just the functionality of it on a FWD car was questionable.
Postby JamesT » Fri Sep 25, 2009 1:03 pm
Our cars don't need to be towed - they're too reliable (unless you bypass the knock sensors :wink: )
I think it looks cool. What about putting two in the back, one on either side.
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby DriDed » Fri Sep 25, 2009 1:04 pm
I guess that would be a good protection against parking lot drivers, it doesn't distract me from looking at the body kit so that is a good thing.
I would paint the tow hook flat black so it hides even better.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby k-0tik » Fri Sep 25, 2009 1:53 pm
That looks pretty tight
k-0tik
