SolaraGuy.com • View topic - The BEST Headlight Restoration (pictures)
Postby SirThomas88 » Tue Aug 03, 2010 12:42 am
Okay, so I did this yesterday on my headlights. Here's what I used and the before and after pictures.
It costs $22.99 at Advance Auto Parts. You follow the instructions included, and with a little sanding and applying liquid (all included) you get great results! Took me about 30 mins per headlight. My headlights had severe yellow discoloration, fogginess, and some scratches.
Before (thats not dirt):
After #1:
After #2:
SirThomas88
Re: The BEST Headlight Restoration (pictures)
Postby SleeperSolara » Tue Aug 03, 2010 7:22 am
Good job man.
Postby DSM_Lara » Tue Aug 03, 2010 8:17 am
lol... That's the same one I used. Bought it from Walmart.
DSM_Lara
Postby SirThomas88 » Tue Aug 03, 2010 11:23 am
DSM_Lara wrote:lol... That's the same one I used. Bought it from Walmart.
Cool, how'd it work out for you? This was the second time I used it and both times worked wonders.
SirThomas88
Postby DSM_Lara » Tue Aug 03, 2010 2:42 pm
Only once when I first bought this car back in December 09. But, I have been using it for a while. Used it on my Eclipse(s). Overall I like the outcome.
DSM_Lara
Postby Solarizona » Tue Aug 03, 2010 7:00 pm
Same here. Stuff works awesome. I also got two packs from Amazon for $20 during a sale. Only negative for me was my headlights started getting dull again after about 18 months, but I thought that was pretty good durability.
Solarizona
Postby SirThomas88 » Wed Aug 04, 2010 12:44 pm
I should clarify, I've used that stuff twice, on two different sets of headlights.
Heck yeah, better than paying for a new set!
SirThomas88
Postby TRDSleeper » Sat Aug 14, 2010 1:19 am
I always saw this kit at Walmart and tempted to try it but wasn't sure if it works or not. Now I know it does. There's so many of these headlight restoration kits nowadays from all sorts of brands like Mother's, Meguiar's, Turtle Wax, Rain-X, etc. It's hard to know which ones work or not.
TRDSleeper
Postby SirThomas88 » Sat Aug 21, 2010 9:24 pm
Yeah, I've tried a couple of them before. One had me putting a special buffing bit into my drill and applying cream to it... did hardly anything.
This stuff is for real though.
SirThomas88
Postby St.Anton » Thu Jul 14, 2011 12:56 am
Yooo just tried that Turtle Wax stuff. It was alllllriiighhttt.
Before and After
Had my detailer homie go at it afterwards. He got even better results.
Before and After
St.Anton
Postby 2Gud2BTru » Thu Nov 17, 2011 1:26 pm
If you want a cheaper way, try this: buy meguiars $8 PlastX clear plastic cleaner and protecter. first wash the headlights with some dish soap and water. then rinse, dry. After that, put the PlastX on like a basic towel, rub the stuff onto the headlight. IMMEDIATELY AFTER covering the entire headlight, wipe off with a dry side of the towel. Buff out any excess. Repeat any time you wash your car (optional). Though scratches may not be removed, the clarity of the actual headlight plastic is crystal clear. i have been using this for months and my headlights look great.
-01' SLE v6 coupe:Traded in. 223k
-06' Accord Coupe 4banger: DD
2Gud2BTru
Postby DSM_Lara » Fri Jan 20, 2012 4:28 am
Had to use this product again this past Friday... Front is restored and back still needed to be done.
DSM_Lara
Postby 1gSE » Fri Jan 20, 2012 5:21 am
I used the 3M stuff before. SirThomas is that what you used? It work pretty well, but I didn't keep up with it, so now the right side needs some more work. I might be able to just use some polish and that should take care of it
Solara-M62 @ 5.5psi
1gSE
Postby Billdo » Tue Jan 24, 2012 4:53 am
I used standard rubbing compound, per the advice of a friend who has a detailing shop, and it looks great. He said these kits most times are just compound or at least mostly compound anyway.
Billdo
Postby SirThomas88 » Fri Mar 16, 2012 1:37 pm
I didn't use the 3M stuff. I used the "CV" brand stuff pictured in the original post. The other day I bought and used the Turtle Wax brand headlight restoration kit and it worked about as well as the CV brand.
The CV brand has about half the steps than the Turtle Wax, but the final step in the CV brand one you have to be careful or you'll mess up the whole process. The final step in the Turtle Wax one is more forgiving.
SirThomas88
