SolaraGuy.com • View topic - need advice. oxygen sensors
Postby AlexSP » Thu Jun 02, 2011 5:40 am
Hi All
Sorry if this topic exists.
Q: I have a Solara1.
2 oxygen sensors.
How to get around them to install an exhaust system and that the brain does not hang?
Sorry for maybe the wrong grammar, I'm not really in it.
Thanks in advance!
AlexSP
Re: need advice. oxygen sensors
Postby 1gSE » Thu Jun 02, 2011 10:33 pm
Um....I"ll give it a shot. You're worried about your o2 sensor hanging in open air while you install an exhaust, correct? I'm not sure if you're concerned about damaging the sensor itself, or the wiring by it just hanging around. Either way you'll be fine. Just don't run the car with the sensors installed but not plugged in.
Solara-M62 @ 5.5psi
1gSE
Postby AlexSP » Fri Jun 03, 2011 5:39 am
Well .. if I put a sport exhaust system without a catalyst or catalyst with a low resistance that the brain does not understand and I needed something to do with the second O2 sensor
but here's what to do?
AlexSP
Postby hskrsolara » Fri Jun 03, 2011 6:11 pm
URD sells o2 simulators that wire into your ecu, bypassing the signal (or lack there of) coming from your sensors. Buy one, they'll take care of your problem.
hskrsolara
