SolaraGuy.com • View topic - 9006 to 9005 conversion for foglights
Postby MGLax13 » Sun Oct 12, 2003 3:37 pm
9005's are much brighter than 9006's and after I did this conversion to my Accord, I never wanted to go back again, now when I get a chance, I'm going to do this to my Solara. It's a very easy mod but as is with any DIY, do it at your own risk and I assume no responsibility for any damage or injuries.
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Hsakuragi » Sun Oct 12, 2003 4:07 pm
you gonna blind somebody :o
Hsakuragi
Postby krawzyazn » Sun Oct 12, 2003 7:00 pm
remember it gets hotter
Postby MGLax13 » Sun Oct 12, 2003 8:17 pm
It might blind somebody, it works great in my head lights in my Accord. Now once I get a chance to do it to the Solara, I'll take a pic with a 9006 and a 9005 so you can compare. It does get hotter, but not enough to burn anything out or cause any damage. Unless you kept your fog lights on for quite a long time.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby impactX » Sun Oct 26, 2003 1:25 am
I have the 9005 conversion for my fog lights, I turn them on when necessary and they are brighter.
impactX
Postby Ruski » Mon Oct 16, 2006 4:24 pm
i plan on driving with my fogs on all the time when i do the fog light rewiring.
Will this effect anything or burn/melt the harness ??
I understand about blinding other drivers
Postby Ruski » Wed Oct 18, 2006 7:42 pm
^^^ Anyone ???
Postby WTF?? » Wed Oct 18, 2006 7:56 pm
Ruskimafia wrote:i plan on driving with my fogs on all the time when i do the fog light rewiring.
9005's use 65W, wheres as our 9006's use 55W
This means that it is going to work more and will get hotter than normal like krawzyazn said previously in this thread...
If you decide to run it "all the time" your chances of burning your wiring harness is much greater than using your fogs occassionally.
Retired... its been fun Image
WTF??
Postby woa_its_j3ff » Wed Oct 18, 2006 8:28 pm
id be careful and just stick with 9006.
Postby Jai_Jai_Binks » Wed Oct 18, 2006 8:49 pm
You would replace your bulbs more frequently (or like other stated your wiring harness). Luckily for me it was always the bulbs on my celica. (I had rewired my bulbs and ran 100W).
http://www.cardomain.com/member_pages/s ... 3_full.jpg
Postby Eye8Pussies » Wed Oct 18, 2006 10:36 pm
you'll be fine in regards to the heat.
I've been running 9005s as low beams for 4 yeras now and no real problems.
But it is a good idea to replace your harness though- more for the socket attachment than the wires though.
If you just modify the bulbs, they still don't hold as well as an original 9006 bulb and they can move around a bit. For me, both my harnesses melted at the socket on the inside where you can't see it unless you take out the bulb.
And there is a bit more glare. In the gen3 camry's stock headlights it wasn't that bad though.
Postby Ruski » Thu Oct 19, 2006 7:23 pm
Ight thanks alot guys. i guess ill jsut stick with stock 9006 dont feel like Fing up the harness
Postby lilm » Sat Oct 21, 2006 11:42 am
ive been running my fogs like this for over a year with no problems and my fogs are on 100% of the time hehee i think it looks cool with just fogs and corners so there like that till night time
lilm
Postby Ruski » Sat Oct 21, 2006 1:24 pm
I love that look to
Postby Akfahad » Thu Nov 16, 2006 1:46 pm
Just did this mod last night and threw them on...not too bad, but not that brilliant yellow I was looking for. But...since it was raining today, I put on the headlights and fogs for maybe 15-20 minutes. Now the fogs don't come on at all. I switched them back to sylvania 9006 and still nothing. Checked the fod circuit breaker under the dash, not cracked.... Anybody got ideas?? Burnt harness? but only after 15-20 mins., come on?!?!
