SolaraGuy.com • View topic - oil change on the 1mz-fe
Postby AzN_DrAgoN48 » Sat Jan 03, 2004 8:56 pm
i know this is pretty much general info but i didn't see anyone post anything about changing the oil in the 1mz-fe.
1. go buy any kind of 5w-30 oil and an oil filter of your choice (look in the little book if you don't know which filter). buy 5 quarts of oil
2. cool the engine.
3. either use a car ramp, or jack and jack stands to get the front of your car up.
4. locate the oil pan. its close to the front passenger side wheel, you'll see it.
5. get a socket wrench and find the right socket and remove the bolt/ plug. it might take a little force.
6. drain the oil.
7. once the oil is done draining, remove the oil filter. there is oil in the filter so make sure you have something to collect it. the filter is located right under the headers.
8. get your new filter and lube up the brim with the new oil.
9. screw the filter on.
10. replace bolt/plug. make sure the gasket is on.
11. pour new oil in. use about 4.5 quarts.
12. lower the car.
sorry if this is stupid, just for the people who don't know how to change the oil in the 1mz fe. correct me if i'm wrong about anything.
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby Hsakuragi » Sun Jan 04, 2004 12:56 am
clarification: 5 qts of oil for 1mfze
if you left over for a day to get the oil complete drain, use 5.2 qt
if you didn't change the filter, put 4.7 qt
Hsakuragi
Postby geminimouse » Sun Jan 04, 2004 1:12 am
umm...shouldn't the engine be warm?
and you can buy other ratings of oil besides 5w30. Just depends on what u prefer.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Yanks0114 » Sun Jan 04, 2004 10:42 am
hsakuragi wrote:clarifacation: 5 qts of oil for 1mfze
The 1MZ was actually designed for 4.5 qts of oil. Its in the manual.
A couple of additions.
Warm the car up for 2 minutes, the oil drains better
Be sure to manually thread the oil pan plug back in and then use the socket, you don't wanna strip that.
Start up your car, let it run for a little, shut off your car and check the oil level
Postby Yanks0114 » Sun Jan 04, 2004 10:44 am
Here is an additional article on how to change your own oil
http://www.edmunds.com/ownership/howto/ ... otips.2.*#
BTW use 5w30 in the colder climates and 10w30 in the summer when it gets real warm
Postby Hsakuragi » Sun Jan 04, 2004 3:05 pm
to prove my statement is right, here is the file, originally from the Toyota Service Manual
http://community.webshots.com/photo/942 ... 9412kjzrHF
http://community.webshots.com/photo/942 ... 9315wJuEGc
Hsakuragi
Postby AzN_DrAgoN48 » Sun Jan 04, 2004 3:40 pm
sorry about that. when i said cool the engine i meant if you just drove the car.
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby bkp_duke » Sun Jan 04, 2004 4:25 pm
read a little more carefully,
4.5 w/o filter change
4.7 w/ filter change
that 5.2 is only if you could get the oil out of the lifters, etc. you can't do that by draining overnight. nor would you want the inside of your engine exposed to the open moisture and air overnight.[/quote]
bkp_duke
Postby geminimouse » Sun Jan 04, 2004 4:59 pm
u should read even more carefully. :)
4.8 qts w/o filter change
5.0 qts w/ filter change
08 Accord Coupe
geminimouse
Postby Hsakuragi » Sun Jan 04, 2004 7:30 pm
thanks mouse!
we need a math class here..lolz :D
Hsakuragi
Postby adam2562 » Thu Jan 08, 2004 5:52 pm
at toyota its 5 qts w/ filter change and 4.7 w/o filter change... i do it everyday
Adam - 99 V6 5spd 165k -SOLD
adam2562
Re: oil change on the 1mz-fe
Postby SolaraT » Fri Jan 16, 2004 5:26 pm
AzN_DrAgoN48 wrote:Sorry if this is stupid, just for the people who don't know how to change the oil in the 1mz fe. correct me if i'm wrong about anything.
This is not stupid, look at what it caused. More information and tips! I love this place. This basics apply to the 5SFE also except maybee for the amount of oil.
Adam, you do this everyday, how much for the 5SFE? I was putting 4.5 w/filter change and it was to the max. 8)
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby adam2562 » Fri Jan 16, 2004 6:51 pm
4.5 :o on 5S-FE we do 4 with filter change and 3.7 -3.8 w/o filter change .. cuz the 1mz-fe hasa bigger filter which hold more.. the 5s-fe has an A2 filter... the 1mz-fe has a B1 which is now a D1 filter pre-lubed
adam2562
Postby SolaraT » Fri Jan 16, 2004 7:36 pm
Good info. I never knew the actual amounts. I was going by the oil stick. Thanks bro.
2007 VW GTI
SolaraT
Postby adam2562 » Tue Jan 20, 2004 2:38 pm
yulp.. no problem
adam2562
