SolaraGuy.com • View topic - PCV Valve
PCV Valve
PCV Valve
Postby bassthrive » Tue May 25, 2004 3:19 pm
Super-easy replacement of a critical engine part you can do yourself!
Looking under the intake manifold from the passenger side you will see the little guy (refer to picture). Just unplug the old and plug in the new. Folks with superchargers may have a tougher time.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby 808Camry » Wed May 26, 2004 12:41 am
why did you have to replace yours and how much was it?
808Camry
Postby bassthrive » Wed May 26, 2004 9:56 am
The PCV valve is just another part of regular preventative engine maintenance.
I replaced mine at 60k, but the part is so cheap ($4) that you can use an even shorter interval if you wish.
Check this thread http://www.zer0.info/solaraguy/viewtopic.php?t=2742
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby esculatus » Wed May 26, 2004 6:36 pm
cool thanks! I'll try to do it this weekend
update: did my change. It's kinda tight in there with the S/C. I follow what the Haynes manual says and try checking for the valve performance. Turns out my old one is fine. But I replace it anyway =)
Nice tutorial! I found it really easily!
esculatus
