SolaraGuy.com • View topic - Clean your throttle body
Postby whiteflash » Fri Jul 16, 2004 7:38 am
Did mine yesterday and i notice when i floor it there is a little bit more kick to the car i guess cause theres more air getting through so freaking easy but i got no white smoke just the puttering
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby oompah2788 » Thu Jul 22, 2004 4:56 pm
i think ima have to try this too, but what do you guys think of the injector cleaners?? the one you put it the gas tank?? you think that actually works and if it does does it make a noticeable difference? Thanks
oompah2788
Postby Jon11582 » Thu Jul 22, 2004 5:09 pm
I just did mine last week. I was expecting all this caked on goodness, but it wasnt dirty at all though, even after 46K and the original filter. Maybe its because I got a I4. About two sprays and about a 30 seconds of brushing got it clean and residue free. Outside of the butterfly valve, it was completely clean, you could still see the brass colored metal.
2000 Black Solara SE
Jon11582
Postby groovespacer » Sat Jul 24, 2004 12:09 pm
Yeah the outter part generally stays clean its on the other side of the butterfly, that is ddirty.
groovespacer
Postby lazyboyz69 » Sun Sep 19, 2004 12:57 am
should you clean it with teh supercharger..... cuz i did and i think i lost some boost.... i'm not sure.... or is it me....
lazyboyz69
Postby Rudy » Sun Sep 19, 2004 2:55 pm
lazyboyz69 wrote:should you clean it with teh supercharger..... cuz i did and i think i lost some boost.... i'm not sure.... or is it me....
It's you
99 Solara V6 5SPD
Rudy
Postby 209solara » Thu Sep 30, 2004 10:28 am
Awesome tutorial, just did mine on a 99 V6 with just over 70k. It was very dirty, but simple to clean. I also used the stp intake cleaner, like $3 at auto zone. I will be using the valvoline synpower fuel system treatment once i gas up again. And Ill be getting my injen tommorow, so thought i might as well give it a clean home 8)
209solara
Postby randomman84 » Thu Nov 11, 2004 1:13 pm
holy crap that worked great. the car is so much smoother in accelerating now! Thank you soo so much!
randomman84
Postby gSx8o » Fri Nov 12, 2004 5:58 pm
thanks a lot for the tutorial bro
i got the job done on the 5S-FE with 111k mi
pretty much the same procedure
i wouldn't have done it without reading this topic
<body>
<img src="http://gsxonline.com/images/8o_white.jpg"><br>
Currently own: 2000 Solara SE 5S-FE Auto
</body>
gSx8o
Postby randomman84 » Sat Nov 13, 2004 11:03 pm
here is some photos, i forgot to post them b4.
before
after
sorry the pics are blurry having camera issues.
randomman84
Postby jerold » Thu Feb 17, 2005 7:10 pm
hey, i got the STP cleaner, and sprayed the crap out of my throttle body, but now i got a code 505, idle control system malfunction. what did i do wrong? and how do i go about fixing it? i tested the IAC like the Haynes manual said. it seems fine.
after i drove it, the throttle seemed stuck. not when gassing it, but when letting go of the gas. it would still go for a couple of seconds, before backing off.
2000 camry
jerold
Postby Midias » Wed Feb 23, 2005 10:18 am
I also removed theback plate off the V6 manifold and cleaned that out very good
Postby RichD978 » Thu Feb 24, 2005 7:02 pm
Is it safe the drive about say half an hour (10 miles) and clean the throttle body once i arrive at the destination? Or should I wait for the car to cool down? If so , how long would i wait?
RichD978
Postby RichD978 » Fri Feb 25, 2005 12:15 pm
can someone please answer ^^^^ thanks
RichD978
Postby bassthrive » Fri Feb 25, 2005 1:40 pm
Engine temp shouldn't effect cleaning, aside from it being a little uncomfortable to work around a hot engine.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Users browsing this forum: No registered users and 2 guests
