SolaraGuy.com • View topic - Post your DIY Requests Here
fender and bumper
Postby Orefus » Sat Feb 17, 2007 7:57 pm
fender and bumper removal diy please
Orefus
Postby unbalancedwood » Sat Feb 24, 2007 10:14 am
Install the front/top valve cover gasket!
unbalancedwood
Postby nemoxfishy » Tue Feb 27, 2007 12:33 am
Does anyone know how to disable the auto lights on at night?? I believe it's not the same as the DRL.
Please help me out
nemoxfishy
Postby unbalancedwood » Tue Feb 27, 2007 8:19 am
thats the DRL, daytime running lights...
unbalancedwood
Postby Yanks0114 » Tue Feb 27, 2007 11:28 am
nemoxfishy wrote:Does anyone know how to disable the auto lights on at night?? I believe it's not the same as the DRL.
Please help me out
There is a sensor in the top-right corner of your dashboard that controls auto-on. You can pop the sensor up 1-2" with a flathead screwdriver. I always planned to put a switch on one of the leads to the sensor. It'd be nice to temp auto-on when I'm in the garage or places like that, but I never found enough information.
Unbalanced - he was referring to a sensor which determines if its nighttime and automatically turns on your headlights. Different than the DRLs.
Postby nemoxfishy » Wed Feb 28, 2007 6:11 pm
Please help me out
got it!! i unpluged the senor and its perfect!! thxthx!
nemoxfishy
Fog Light Install
Postby Orefus » Mon Apr 16, 2007 4:11 pm
Fog Light install DIY PLEASE!
Orefus
Postby facevedo17 » Mon Apr 16, 2007 4:18 pm
Astro wrote:How about Jim's Fuel Kit mod? I recently purchased and awating arrival. This will be my first time doing anything with the fuel system.
I recently purchased one aswell need help on this one
facevedo17
Postby aleki2424 » Sun Jul 01, 2007 8:32 pm
anyone know how to get to the o2 sensors. have no idea whea it is , and my light came back on
aleki2424
Postby Silver2000Solara » Fri Jul 06, 2007 2:57 am
I heard that the stereo comes with a code to program it if the battery is taken off, I'm guessing for anti-theft purposes. Is this true? And if so, are there instructions on programming your stereo?
Silver2000Solara
Postby PapaDukes027 » Tue Aug 07, 2007 9:19 pm
Replacing bulbs behind speed, rpm gauges pretty please :wink:
'99 SLE V6
Renova Grill
Injen 2030 Intake
PapaDukes027
Postby woa_its_j3ff » Tue Aug 07, 2007 9:43 pm
PapaDukes027 wrote:Replacing bulbs behind speed, rpm gauges pretty please :wink:
simple. remove top 2 screws. remove 4 screws once you remove the black bezel-thing.
pop out the unit slowly then unhook wires, remove the spedo cluster all the way.
turn it around so the rear is facing you.
replace the 5 bulbs (green base) bulb size is 194.
Postby PapaDukes027 » Wed Aug 08, 2007 6:40 am
Thanks jeff. I kinda figured it was simple i just wanted to make sure before i pulled some wire i wasnt supposed to.
'99 SLE V6
Renova Grill
Injen 2030 Intake
PapaDukes027
7- piece-TRD body kit/3m tape... installation tips. w pic.
Postby LatinUSMC » Mon Nov 05, 2007 4:20 pm
need a pic tutorial of how to attach the TRD 7 -piece body kit on..its already separating from the bumper..on some spots you can see the 3m tape not holding on...what gives??? :evil:
LatinUSMC
Postby BLACK V6 » Wed Jul 23, 2008 8:27 pm
Changing the transaxle fluid...
BLACK V6
