SolaraGuy.com • View topic - Current 04 Solara TSBs as of 8/2
Postby technole » Mon Aug 02, 2004 2:29 pm
00304 - A/C COMPRESSOR INSTALLATION PROCEDURE.
00204 - POOR RADIO RECEPTION.
00204 - VEHICLE PULL IMPROVEMENT PROCEDURE.
01404 - EXCESSIVE SULFUR DIOXIDE ODOR (affects only 2002-2004 2AZ-FE engines)
00804 - MOON ROOF (SLIDING ROOF) RUBBING/SHUDDERING NOISE
02503 - WATER LEAK CONDITION AT THE FRONT FLOOR AREA
01204 - TONNEAU COVER IMPROVEMENT.
00704 - REAR PACKAGE TRAY RATTLE.
2004 Solara V6 SLE w/XM Satellite Radio
technole
Postby Mole » Mon Aug 02, 2004 2:33 pm
so radio reception is a tsb???
Postby technole » Mon Aug 02, 2004 2:34 pm
TRDMole177 wrote:so radio reception is a tsb???
Yes sir, its been one for a few months now.
technole
Postby got sport » Mon Aug 02, 2004 2:38 pm
I'm glad I don't suffer from any of those TSB's.
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Postby technole » Mon Aug 02, 2004 2:46 pm
technole
Add one
Postby jmack » Mon Aug 02, 2004 3:06 pm
Please add TSB # EG007-04 Replacement of ECM for throttle response.
jmack
Re: Add one
Postby technole » Mon Aug 02, 2004 3:45 pm
jmack wrote:Please add TSB # EG007-04 Replacement of ECM for throttle response.
Is that really included in the 00704 for the Solara? The only Solara ECM issue that I know has a TSB out is for the odor in the 4cyl. The only bulletin for the Solara in the 00704 as far as I know is the rattle issue.
technole
ECM TSB
Postby jmack » Mon Aug 02, 2004 4:40 pm
I don't know. Went to dealer for problem with terrible lag in throttle response when stepping on the gas, they said there was a TSB, and that is the TSB on the receipt. Whether it is official, or pirated from some other Toyota with a 3.3 engine, I think that all V6 owners should be aware of it, as it is a potential safety issue. Maybe one of the members that works for Toyota can confirm. I just know what was told by dealer.
jmack
TSB source?
Postby DocJohn » Mon Aug 02, 2004 5:51 pm
Where is the best source to download these TSB's for the '04 Solara? (The Toyota's Only! site http://groups.yahoo.com/group/Toyotas_Only doesn't have most of these listed above).
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby mattyboyl » Tue Aug 03, 2004 6:24 am
Could technole explain what is done with this TSB: 00804 - MOON ROOF (SLIDING ROOF) RUBBING/SHUDDERING NOISE
This has been a very annoying issue and am curious on what is the cause and remedy for this situation.
Could you also explain this one: 00704 - REAR PACKAGE TRAY RATTLE
Does this just require the removal and replacement of the rear deck tray?
mattyboyl
Postby 04solarafanatic » Tue Aug 03, 2004 7:06 am
Yieks I just realised my rear deck rattles when I play loud music.....I tested this by fading to the sound to the rear only and you can clearly haer the rattle.
That stinks...if I want to get thsi fixed...what do I tell the dealer?
I also have left drift prob...I was driving in 287 with my bro's 2001 altima and his car did not drift to the left....my new 04 solara does....
This really stinks.,,,I appreciate any help..as this forums is excellent.
Thanks in advance!
04solarafanatic
Postby trdpower04 » Tue Aug 03, 2004 10:36 am
hmmm, mine suffers from the rear package tray rattle, and the moonroof shudder....off to the dealer we go.....
2004 Toyota Solara SE Sport V6
Arctic Frost Pearl
trdpower04
Postby DocJohn » Tue Aug 03, 2004 1:13 pm
I would be interested in seeing the TSB's on:
Does anyone have a copy (PDF file)?
I have the PDF for 00204 - VEHICLE PULL IMPROVEMENT PROCEDURE. if any one is interested in seeing a copy.
DocJohn
Postby Justaplaythang » Tue Aug 03, 2004 1:43 pm
DocJohn wrote:I have the PDF for 00204 - VEHICLE PULL IMPROVEMENT PROCEDURE. if any one is interested in seeing a copy.
Me please, Id appreciate it. I just scheduled an appt for the sulfur odor problem. I thought I was goin crazy, smelt it 3 times in the last 1.5 weeks.
Justaplaythang
Postby technole » Tue Aug 03, 2004 2:07 pm
mattyboyl wrote:Could technole explain what is done with this TSB: 00804 - MOON ROOF (SLIDING ROOF) RUBBING/SHUDDERING NOISE
The moonroof I'll have done this weekend. But I was told they have to remove the roof and to cycle it open/close with the glass removed, if the noise goes away it is said that the moonroof glass needs to be replaced, and if it does not the problem is more likely in the frame or cables and not the moonroof glass.
The rear package tray rattle has something to do with adding felt to retaining tabs on the tray. It does not require a replacement.
technole
