SolaraGuy.com • View topic - sunroof
sunroof
sunroof
Postby xodessitx » Sat Aug 07, 2004 12:36 am
i have a concern regarding the sunroof. maybe someone can explain this to me. when my sunroof is closed, and it is raining out side, there seems to be water seems to be entering not in the front,but in the back. the dealer told me this is normal, because there are 2 water channels, one in front and 1 in back for water drainage. has anyone had this problem, or knows wats goin on.
did anyone have their rubbing noise fixed when the sunroof is opened during hot days?
2004 solara
se sport v6
lunar mist
getting tints probably 20% all around
more coming soon.....
xodessitx
Moonroof
Postby clarkman » Sat Aug 07, 2004 5:09 am
Regarding the water leak, is water entering the cabin in the back? If so, then probably a drain house has a problem (ex.; hole, not connected, etc.). Regarding the noise, does the noise just occur at the start of a cycle on hot days? If yes, then it is functionally OK. More grease in the bracket channels should fix the noise.
clarkman
Postby xodessitx » Sat Aug 07, 2004 6:59 am
well the water does not enter the cabin, but it is in the water channel, and is it a normal thinng for water to be there when it rains.
the noise is only on hot days, the dealer lubricated the tracks of the sunroof about 3 times now, and it still the same noise on hot days, anyother suggestions concerning this problem
2004 solara
se sport v6
lunar mist
xodessitx
Postby Shoe » Sat Aug 07, 2004 9:21 am
a leaky sunroof dosent sound normal to me
sounds more like a cheep excuse by your dealer
your car must have so much moisture in it its been a wet summer do your windows fog up on the inside on hot nights?
shoe
Shoe
Postby TW85 » Sat Aug 07, 2004 5:44 pm
Everything is normal to a dealer until the word "safety" is mentioned Then MAYBE, just maybe, they will raise an eye...and then quickly look away again. Most dealers are almost worthless. :roll:
If water is sitting on the inside part of the sunroof, it is not normal. It is also not normal to have the rubbing sound we have and it seems no one has found a successful fix...
Moved on to better things...
TW85
Postby trdpower04 » Sun Aug 08, 2004 4:11 am
Ya, my sunroof makes that terrible noise every time, hot or cold. It is going to the dealer 8/12, also for a squeak in the left front corner of the dash, and a rattle in the rear deck. Yay! I will keep you posted if the fix it. They tried greasing it once, and guess what? Didn't fix it.
2004 Toyota Solara SE Sport V6
Arctic Frost Pearl
trdpower04
Postby xodessitx » Sun Aug 08, 2004 7:13 am
for the noise in the rear deck what i have done is the followin:
the cover on top of the spare tire on the left side where the tools are makes ratling noise when driving, what i did was that i took a piece of cloth and put in directly under that spot. it seems that most of the ratling has went away. you should try to do this it may help. i have also had some nosie from the dash board, did u ever have any ratling noise from the sunroof area?
2004 solara
se sport v6
lunar mist
xodessitx
Postby michaels artic frost » Sun Aug 08, 2004 7:58 am
There was a thread a while back in regards to the sunroof making loud noise. Do a search on it and you'll find some useful infos. :D
Updated 06/01/12: Michael T's
fixes
Postby clarkman » Sun Aug 08, 2004 12:18 pm
Package tray rattle: put felt on the package tray tabs to fix.
IP (LH front) fix: Put felt on speaker nut. Pop cover off to get to nut.
Sunroof. The sunroof is designed the catch some water and allow it to drain out through attached tubes. If it is not draining correctly, check for debris blocking the water's exit.
clarkman
Postby xodessitx » Wed Aug 11, 2004 8:20 pm
how can the dashboard rattle be fixed, i dont understand, can u plz explain. thanks
2004 solara
se sport v6
lunar mist
xodessitx
IP Noise
Postby clarkman » Thu Aug 12, 2004 3:53 am
1. Noise from speaker nut: more like a tick noise. If you pop the speaker cover off of the IP speaker, you'll see two gold colored nuts. Put felt over both. Then put cover back on.
2. Noise from center back of IP: also tick noise. Remove cowl cover and wrap foam tape around the bottom of the windshield.
3. Noise from A-Pillar:tapping noise. Put foam tape along the metal tube under the garnish.
These are just some possibilities without having to remove the IP. If these are not the source of the problem, try looking through HVAC vents, radio opening, etc. and try to see loose wires.
clarkman
Postby pantyninja » Thu Aug 12, 2004 5:36 am
My car is in the shop right now. I had the gaskets lubricated for the moonroof then 3 days later it wouldn't even slide back. Now the gasket got ripped off when I tried to slide.
Dealer is ordering new cables and gasket. TOld me he got it to open to diagnose now it won't close. THere is definitely a sunroof problem that is more than meets the eye
Rejoice O Young Man in thy Youth
04 SE-V6 sport
Absolutely Red
pantyninja
Postby xodessitx » Thu Aug 12, 2004 7:06 am
im sry for inoign you, but what is the IP. u mean the speaker on the corners of the dash board. do you mean i should like tighten them up if they are loose. what is the cowl cover, and the a-pillar. can you just be more specific, plz.
thank you
2004 solara
se sport v6
lunar mist
xodessitx
