SolaraGuy.com • View topic - emblem adhesives
emblem adhesives
emblem adhesives
Postby dvdchris45 » Thu Aug 19, 2004 12:01 am
Alright, so I noticed when I took out my 'Toyota" and 'Se' emblem and replaced em with a 'VVT-i" one, it was kind of this unique clay/sillyputt/ adhesive that stuck once you put on and wont reattach when you remove them. Im curious to know what kinda adhesives/taped they sell out there (maybe like a 3M type of thing) that will stick if I wanted to do some emblem adding/swapping, something to withstand weather and/or watering. Maybe if something good is out there you can de-badge your car (assuming you want to) without having to worry about re-sticking them at your heart's desire.
OH yeah, and sometimes it seems like my 'vvt-i' sits a bit lower than the 'v-6' maybe the the lighting. Nevertheless, I need some peace of mind on removing/re-attaching emblem w/o worries!
Thanks
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby dvdchris45 » Thu Aug 19, 2004 12:03 am
sorry for the type-o's , It's too late at night to proofread. :sleeping:
dvdchris45
Postby boaclub923 » Thu Aug 19, 2004 12:47 am
regular white 3M double side tape is strong enough to hold it. and it's easier for cutting. if u really wnat the same tape as the stock one, u might have to go place like HomeDepot. i know they have it there, dark gray double side tape. but it's super sticky, and u can barely cut it into the shape that you one, espeically the sign "V6". lots curve on "6".
boaclub923
Postby mattyboyl » Thu Aug 19, 2004 6:27 am
I'd go 3M myself. Make sure you can get the thinner kind though.
mattyboyl
Postby kmccomb » Fri Aug 20, 2004 10:16 pm
What is the best way to remove emblems? Should I pay for someone to do it?
kmccomb
Postby dvdchris45 » Fri Aug 20, 2004 11:38 pm
no dont pay anyone, its rather simple.
the 'TOYOTA' 'V6' and 'SE' emblems are stuck on by an adhesive. the huge Toyota logo and the 'SOLARA' are held down by pins, so if u take em off there will be holes. As for the other three emblems, what I did was I warmed them up using a hairdryer and got some strong floss and "flossed it out". You should be able to remove it by just "flossing'' it and gently pryin it out, its very easy as a matter of fact. Once its off you can try and peel the leftover adhesive by hand or wash it away with some warm water and soap.
dvdchris45
Postby kmccomb » Wed Aug 25, 2004 11:36 am
Thanks for the tips DVDchris!
2004 SLE Conv.
Black w/ Tan top
Ivory interior
Stock Everything (Working on that)
kmccomb
