SolaraGuy.com • View topic - Picking up my car on 8/21..Need advise/input
Postby online » Thu Aug 19, 2004 6:39 pm
Finally...My 05 absolute red/blk top convertible has arrived and I will taking ownership on Saturday:D !
I am asking for guidance/advise on what I should be looking for in regards to checking for defects, possible trouble areas, walk through etc with the dealer.
I would really appreciate any and all input on what you think are the key points I should focus on when doing my pre-acceptance inspection.
Thanks in advance!
online
Postby Mole » Thu Aug 19, 2004 6:47 pm
in your case, most likely there are no defects.
you can check the odometer to see how many miles are on there.
check the hood to see if anything may leak.
anything under the car, see if there is any rust.
stains on the interior.
rock chips on the exterior.
there really should not be any of those in your new car.
Postby Lone Solara » Thu Aug 19, 2004 7:01 pm
Make sure you check the top for a defective tension cable. Quite a few of us have this problem. There's a thread called "Major Convertible Top Problem" that has a lot more info.
http://www.zer0.info/solaraguy/viewtopic.php?t=10491
Otherwise, just make sure you have a full tank of gas. You might use it all on Saturday (if it doesn't rain.) I hope you enjoy it as much as I enjoy mine !!
Lunar Mist Metallic
Dark Stone Interior
Black Top
K&N air filter
Lone Solara
Postby Ikhandi » Sat Aug 21, 2004 10:01 am
I would definitely advise you to not get dealer prep. Meaning don't let them wash or wax your car, or detail the interior. Most often they only put more scratches and swirls in your paint. Congrats on your 05 Now is the time to time really invest some time into learning how to best care for your finish(washing, polishing, and waxing) Check out www.autopia.org
2004 Toyota Solara SLE V6
Lunar Mist
On a quest to find a bling-like shine!
Ikhandi
