SolaraGuy.com • View topic - Changing Airfilter - 3.3 litre
Postby online » Mon Aug 23, 2004 3:52 pm
not being overly mechanically inclined and the car only being 3 days old, I wanted to make sure I only take apart what I need to replace the air filter.
Looking at the airbox there appears to be 2 nuts on one end. Are removing these all I need to do before attempting to pop the airbox up?
Thanks in advance
2005 SLE Convertible
Absolute Red - Black Top
Nav System
K & N Filter
Mud guards
online
Postby DocJohn » Mon Aug 23, 2004 5:18 pm
I installed the TRD filter in my Solara last month without much difficulty. You need to remove the 2 bolts as you have said. I also removed (pulled off) either one or two small vacuum hoses from the front of the air box to give me a bit more access to the filter.
Take a good look at the position and alignment of the OE filter and then put your new one in exactly the same way.
I recall the hardest part was getting the bolts to line up again when putting it back together. Start each bolt just a turn or two first and then tighten each of them a few turns at a time to keep things lined-up properly.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby mattyboyl » Tue Aug 24, 2004 6:05 am
Also, make sure you install the filter in the right direction. This is very important because I had it in wrong and had a hell of a time tightening the box. Then I took out the filter and turned it and it sealed up tight and without a problem.
mattyboyl
Postby 4Runner4Christ » Fri Jan 19, 2007 9:27 am
I know this sounds noob, but the location of the airbox is not obvious to me, and the owner's manual does not show how to replace the filter. If you are standing in front of the car (with 3.3 engine) where would the airbox be located? Thanks
My rig: Black 99 4Runner SR5 4WD. Wifes new car: Black 04 Solara SE Convertible.
Got Eternity?
4Runner4Christ
Postby PhreakdOut » Fri Jan 19, 2007 9:36 am
Look for the air scoop mounted above the radiator. It goes to the airbox located just behind the battery. See below.
Postby 4Runner4Christ » Fri Jan 19, 2007 9:47 am
Thanks my friend! 8)
Got Eternity?
4Runner4Christ
Postby Down2TheC » Fri Jan 19, 2007 11:05 am
Man that's an old thread. But a legit revival nonetheless. Still, it smells a bit like old feet.
Down2TheC
