SolaraGuy.com • View topic - is there a TSB for the slow throttle response ecm issue yet?
Postby mtodde » Tue Aug 31, 2004 6:30 am
I'm trying a different dealer tomorrow (Sandy Springs Toyota) since Team was so bad...I've heard a lot of good things about them but they didn't seem to know about the farting sunroof (I have the TSB for it) and I want them to adjust the ECM too.
I also will have them look @ the rear deck rattle & the phantom tire pressure warnings.
Thanks
2004 Solara V6 SLE
Lunar Mist Metallic
2 time Solara owner (1999 SE V6 MT)
http://www.cardomain.com/memberpage/648891
mtodde
Postby TW85 » Tue Aug 31, 2004 7:39 am
Well, if Sandy Springs' service department is like their sales, you won't have a problem.
I have an oil change in 400 miles and I'm going to try a different dealer. The dealer we have used for the last several years has become virtually useless for service. If I find a dealer that can fix my sunroof then I will have the left drift taken care of as well as possibly having the ECU reset.
Moved on to better things...
TW85
Postby DocJohn » Tue Aug 31, 2004 5:44 pm
TSB# EG007-04 "Replacement of ECM for throttle response" addresses the problem in question here, but I'm not sure if it applies to the I-4, V-6 or both engines.
If anyone has TSB# EG007-04 I would really like to see a copy of it.
Thanks in advance.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby mtodde » Tue Aug 31, 2004 5:47 pm
DocJohn wrote:TSB# EG007-04 "Replacement of ECM for throttle response" addresses the problem in question here, but I'm not sure if it applies to the I-4, V-6 or both engines.
Thanks in advance.
I have that down as addressing the rear deck rattle...I'm bringing it to the dealer. I got SS002R-01 from alldata.com, but you have to pay to see them so I just looked up the titles.
2004 Solara V6 SLE
Lunar Mist Metallic
mtodde
Postby DocJohn » Tue Aug 31, 2004 6:24 pm
Thanks in advance.
I'm pretty certain that I have the correct TSB #.
"EG" is the prefix for "Engine" TSB's. But I also see the rear deck rattle TSB is also 007-04 but probably has the prefix of "NV" for Noise/Vibration.
I know its all a bit confusing, but anyway, if anyone has the TSB for the throttle response problem, that's the one I would really like to see.
DocJohn
Postby mtodde » Tue Aug 31, 2004 6:27 pm
Aha...so there is a method to the madness! Thanks for the explanation. I have a typed list of issues with TSB numbers for them...I'm sure that will make their day.
Thanks in advance.
2004 Solara V6 SLE
Lunar Mist Metallic
mtodde
Postby technole » Tue Aug 31, 2004 6:35 pm
Thanks in advance.
That one can't be it, and its from Sep 3rd last year, if i'm correct thats just a procedure on how to reset the ECU. By resetting such, the car would have to relearn your driving ability. If you have a heavy foot, the ECU adjusts to it.
As I don't think there is a TSB for such a case, the Solara runs on the same "drive-by-wire" as the Lexus ES330, and RX330.
2004 Solara V6 SLE w/XM Satellite Radio
technole
Postby Jackass-Jeff » Tue Aug 31, 2004 7:49 pm
EG007-04
TSB applicable on VIN#s before
4T1CA3#P*4U021575
Models with latter VIN#s have the update installed.
If ECM Circuit tests OK per repair manual procedure, replaced the ECM (PCM).
That's the jist of that TSB.
1GR-FE ftw!
Jackass-Jeff
Postby mtodde » Wed Sep 01, 2004 12:21 pm
They reset the ECM and said nothing changed and that it has been referred to tech support. The throttle response seems to be much better in the limited drive I did going back to the office.
They have ordered a new moon roof, cable & slide assembly for my moon roof issue and a new rear deck. So far it appears they know how to listen. I like having a service consultant so I go to the same person each time; that is they way all dealers should operate.
2004 Solara V6 SLE
Lunar Mist Metallic
mtodde
Postby technole » Thu Sep 02, 2004 4:02 am
mtodde wrote:They reset the ECM and said nothing changed and that it has been referred to tech support. The throttle response seems to be much better in the limited drive I did going back to the office.
Yeah, I have a service advisor as well. Thats the way it should be at most places. Especially if the dealer is a high-volume.
technole
Postby Jackass-Jeff » Thu Sep 02, 2004 4:46 pm
It's hard for high volume dealers... unless the appointments specify a certain consultant... our Lexus dealer does around 220 appointments + walk-ins each day. Our Toyota dealer does about 400 cars (including walk-ins) a day. Other dealers fear us. We have full time positions for positions that don't even exist (stuff advisors should do) lol
1GR-FE ftw!
Jackass-Jeff
