SolaraGuy.com • View topic - Brake Pedal Rattle/Loose
Postby online » Tue Sep 14, 2004 2:08 pm
I've noticed that my brake pedal is starting to make noise when releasing the pedal after braking. Also I took a look and it also seems to have horizontal play - moving the pedal from side to side with my hand. Has anyone experienced this and if so can it be tightened/adjusted.
Thanks in advance
2005 SLE Convertible
Absolute Red - Black Top
Nav System
K & N Filter
Mud guards
online
Postby boaclub923 » Wed Sep 15, 2004 1:29 am
slightly moving is normal. my solara and old accord moves little bit too...
but if it moves a lot!! then u better go check with dealer, it should under warranty. a car is ok with no engine, but not cool with no brake.. -_-;;
boaclub923
Postby xodessitx » Wed Sep 15, 2004 9:41 pm
yes i have had that for a while on my car. does it make some sort of a squeking sound when you press and relaese the brake pedal? cuz mine does..i dunno wat to tell the dealer cuz they are so stupid there? let me know if yu got that fixed, please
2004 solara
se sport v6
lunar mist
getting tints probably 20% all around
more coming soon.....
xodessitx
Postby boaclub923 » Thu Sep 16, 2004 3:03 am
squeaking sounds? from brake? or just padel?
if it's from brake, check ur brake pad if it's out, or check if the rotor is clean.
if it's from padel, it's probably the oil on the spring is out.
you can just go back and tell dealer squeaking sounds from padel, they will just apply some more oil on the top of the padel which connects spring.
boaclub923
Postby online » Thu Sep 16, 2004 5:40 am
The sound is from the pedal. The pedal has play in it when you release it and then it travels probably up to a 1/4 inch upward. The pedal also has play side to side - 1/2 travel. I'll have the dealer check it out. I was just wondering if anyone else had experienced this.
Thanks to all that responded
Nav System
K & N Filter
Mud guards
online
Postby xodessitx » Thu Sep 16, 2004 4:10 pm
did u try to put some more oil on the pedal? and if yes exactly where are you suppose to puyt it on
2004 solara
se sport v6
lunar mist
xodessitx
Postby xodessitx » Tue Sep 21, 2004 5:01 pm
did any get this problem fixed yet?
2004 solara
se sport v6
lunar mist
xodessitx
Postby online » Wed Sep 22, 2004 12:36 pm
I will be settting up an appt with the dealer. Once again there is play in the pedal. It doesn't effect braking in any way shape or form. Its just an annoying noise due to play in the pedal mechanismwhen I release the pedal.
Stay tuned....
Nav System
K & N Filter
Mud guards
online
Postby online » Fri Oct 01, 2004 2:44 pm
Just came back from the dealer. Oil change at 1000miles and had them check the brake pedal noise. No problem was found. Next time the Service Manager will check it out. He wasn't available while I was at the dealership. Not a big deal but I would like to find out if it can be quieted. I'll probably need to sit in another 05 and test for the same condition. I don't recall experiencing the noise the first 500 miles or so.
Stay tuned...
Nav System
K & N Filter
Mud guards
online
Postby junest » Thu Oct 07, 2004 11:16 pm
I too noticed that my brake pedal has become loose. No noise, just have a lot of play vertically and horizontally. I'm taking it to the dealership tomorrow and will update.
2004 Solara SLE V6 Convertible
Webpage
junest
super solara girl
super solara girl
Postby junest » Sat Oct 09, 2004 12:30 am
The service person told me that the loose brake pedal is normal. I guess if enough people complain, they'll open a TSB.
Webpage
junest
super solara girl
super solara girl
Postby online » Sat Oct 09, 2004 6:40 am
Thanks for the update. When I go in for my oil change (3K to go) I will be working with the Service Manager on this. What I want to do is go to a new Solara and check the pedal. If there is no play that will provide the evidence that this condition isn't normal.
Stay tuned....
Nav System
K & N Filter
Mud guards
online
