SolaraGuy.com • View topic - Windows not sealed properly
Postby Addie » Sat Sep 25, 2004 3:00 pm
I have a 2004 Solara and I am having problem with water getting into my car after I wash the car at the car wash. Is anyone experiencing this problem? I had it checked out at the dealership and they told me there is nothing they can do about it, since it's the design of the car and the design does not have the "lips" seal around the windows. Their suggestion is to hand wash my car or to take it to an automatic car wash with the water pressure being lower.
Any other suggestions from any of you? I am very bothered by this. Otherwise, I love my Solara. It drives great.
Addie
Postby Shoe » Sat Sep 25, 2004 3:08 pm
whats wrong with hand washing?
ps this is the introduction part in no way shape or form have you introduced yourself in that post. I think you need to check out how the forum is set up b4 you post again.
shoe
Shoe
Postby mattyboyl » Wed Sep 29, 2004 12:11 pm
I'd go back to the dealer and have them put in writing that leaking windows are normal! That's a pot of crap! I would demand new rubber seals all around the windows. There is no excuse for that. The window is not sealing properly with the rubber seal. Replace the seal. It's that simple! Those guys are idiots. You shouldn't have to tip toe around your car and adapt to it because Toyota refuses to fix it. It's under warranty and this car isn't cheap, so demand this to be fixed. If not, go above their head or go to another local dealership.
mattyboyl
Postby JadedEMOlush » Wed Sep 29, 2004 1:45 pm
I agree... get that from the dealer in writing.
I have owned 3 Solaras, one of them being an 04... the windows DO not leak and should not leak, regardless of the situation.
JadedEMOlush
Postby online » Wed Sep 29, 2004 1:45 pm
What model do you have? If it is a convertible you should not be running it through an automatic wash and there are also recommendations on how you use a hose during washing around the windows. This info is provided in the user's manaual.
2005 SLE Convertible
Absolute Red - Black Top
Nav System
K & N Filter
Mud guards
online
Postby boaclub923 » Thu Sep 30, 2004 12:28 am
i found water leaking problem for my window when i was my car too..
but i found out it's because i turn the water hose to strong and spread it directly to window. the water was strong enough to push the rubber inside and makes water leak into car.
the solution i found was turn the water hose down alittle bit, or rings it from high to low position when spreading near window.
boaclub923
Re: Windows not sealed properly - Addie
Postby michaels artic frost » Thu Sep 30, 2004 5:12 am
Addie wrote:I have a 2004 Solara and I am having problem with water getting into my car after I wash the car at the car wash. Is anyone experiencing this problem? I had it checked out at the dealership and they told me there is nothing they can do about it, since it's the design of the car and the design does not have the "lips" seal around the windows. Their suggestion is to hand wash my car or to take it to an automatic car wash with the water pressure being lower.
hmmmmm...I have washed my car through high pressured car wash and hand-washed it many times with mild pressure water hose many times and have not found this to be a problem.
mattyboyl wrote:I'd go back to the dealer and have them put in writing that leaking windows are normal! That's a pot of crap! I would demand new rubber seals all around the windows. There is no excuse for that. The window is not sealing properly with the rubber seal. Replace the seal. It's that simple! Those guys are idiots. You shouldn't have to tip toe around your car and adapt to it because Toyota refuses to fix it. It's under warranty and this car isn't cheap, so demand this to be fixed. If not, go above their head or go to another local dealership.
/\/\/\/\Do what mattyboyl said/\/\/\/\ You can't let dealerships give you that BS.
Updated 06/01/12: Michael T's
Postby TW85 » Thu Sep 30, 2004 9:38 am
Arg, another worthless dealer. :x
The windows definitely should not leak. I can drench my windows with a strong stream of water and there is absolutely no leakage into the cabin.
I do agree that you should hand wash your car though.
Moved on to better things...
TW85
Postby boaclub923 » Thu Sep 30, 2004 10:09 am
eh!?!?! sounds like my car has problem too!?! @.@
hum, the leaking wasn't that bad in my car...
only 1 or 2 drops of water after a strong water spreading~
wasn't big deal...
so, i will just happy and stay with it~ ^^
boaclub923
