SolaraGuy.com • View topic - bIG BIG problem with my gen 2 !!!!!!!!!!!
Postby sorkang724 » Sun Oct 03, 2004 8:11 pm
hi, i've install the RSB and the TRD springs on my car awhile back......i'm having problems with one of the item and i've no idea which it is....... the back of my car make this weird squeaky noise when i go up and down on my driveway or whenever I'm on a not properly paved road.....is a very loud sound and it is annoyed the crap out of me.....do you guys think is the springs or the RSB ???.....i've rubber tubings on all 4 of my springs..so i really doubt that is the spring myself....i've my RSB on the most aggressive mode. plz post your comments if you have the problem or give me some inputs so i can fix it. thank you
sorkang724
Re: bIG BIG problem with my gen 2 !!!!!!!!!!!
Postby indiglosolara » Sun Oct 03, 2004 8:54 pm
sorkang724 wrote:hi, i've install the RSB and the TRD springs on my car awhile back......i'm having problems with one of the item and i've no idea which it is....... the back of my car make this weird squeaky noise when i go up and down on my driveway or whenever I'm on a not properly paved road.....is a very loud sound and it is annoyed the crap out of me.....do you guys think is the springs or the RSB ???.....i've rubber tubings on all 4 of my springs..so i really doubt that is the spring myself....i've my RSB on the most aggressive mode. plz post your comments if you have the problem or give me some inputs so i can fix it. thank you
sounds like your RSB bushings not properly lubed. I would get some white marine grease and lube the bushings and you should be ok. I had a similar problem with my gen 1.5 RSB, the bushings were not lubs and made the same noise your explaining.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Mole » Sun Oct 03, 2004 10:15 pm
i would use mobil 1 synthetic grease.
did it to my rear sway bar and it has not squeaked for a long long time.
Postby sorkang724 » Mon Oct 04, 2004 2:42 pm
where do i lube on the RSB and where can i get teh lubricants you guys mention on your post ?
sorkang724
Postby indiglosolara » Mon Oct 04, 2004 2:50 pm
sorkang724 wrote:where do i lube on the RSB and where can i get teh lubricants you guys mention on your post ?
you can try autozone. grease the bushings..
indiglosolara
Solara 2 xB
Solara 2 xB
Grease em up
Postby mmcdonald » Mon Oct 11, 2004 6:24 am
The bushings, as you will recall, have slots running lengthwise on their inner diameter. This is where the grease should have gone. You will need an applicator that can get in that tiny space. Better still, remove the bar and lube them up and reinstall them.
I get a minor farting from mine, even with all of the grease that came with. I will have to take Mole's suggestion if it keeps up.
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
Postby GreenSolara01 » Fri Mar 05, 2010 9:39 pm
Search FTMFW!!!!!!!!!!
Same prob. squeaky rear springs I thought. I will grease up the RSB and see if that helps me too.
GreenSolara01
Postby GzNutz » Sat Mar 06, 2010 8:32 am
Teflon tape FTMFW!
Postby GreenSolara01 » Wed Mar 10, 2010 11:25 pm
Well I greased it up and it solved 95% but the RR bushing was more worn then the rl one. the groves that hold the grease were rubbed smoth in spots. These are not ES bushings, they came w/ TRD rsb. dose any one know the comp ES bushings, pref greasable.
GreenSolara01
Postby dvdchris45 » Fri Mar 12, 2010 11:58 pm
GzNutz wrote:Teflon tape FTMFW!
x2
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
