SolaraGuy.com • View topic - (..!..) Warning Light
Postby darksun5183 » Mon Oct 04, 2004 10:09 am
Hi, I'm new here and I've searched through the board but can't seem to find any help on this topic. I'm currently at work and don't have access to my owner's manual but while driving into work, a warning light which looks like this (..!..) appeared, can anyone shed any light on what this means? If this has already been asked please forgive me, I'm just desperate for an answer.
Thanks in advance
darksun5183
Postby got sport » Mon Oct 04, 2004 10:25 am
That's the tire pressure indicator. When a tire's default pressure is not recognizable by the car’s computer, this light will come on. Just in case, check your tires for any nails or any possible deflation when you get back to your car.
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Postby Shoe » Mon Oct 04, 2004 10:43 am
its been known to go on for no reason at all it happened to me last year on the 1st cold day there were no leaks nails ect.
try this thread
http://www.zer0.info/solaraguy/viewtopic.php?t=10990
shoe
Shoe
Postby darksun5183 » Mon Oct 04, 2004 11:01 am
Thanks!
I checked the front tire and it appears to be around 20 psi and the others are around 26-28. Does anyone know what the correct amount should be? I haven't done any modifications to this car... 2004 Toyota Solara SE... according to Toyota's website they are P215/60R16?
darksun5183
Postby TW85 » Mon Oct 04, 2004 11:17 am
The manufacturer recommended PSI is on the drivers door. The front may be slightly lower than the rear...
Moved on to better things...
TW85
Postby got sport » Mon Oct 04, 2004 11:17 am
I believe it's 32 psi, you can check on the sticker on the inside of the driver's door.
got sport
Postby darksun5183 » Mon Oct 04, 2004 11:58 am
Thanks for all the help, I'll definately try to fix this problem as soon as work is over!
darksun5183
Postby mattyboyl » Tue Oct 05, 2004 9:50 am
It's very important to go with manufacturer's PSI and not not the PSI written on the tire.
mattyboyl
Postby dawp » Tue Oct 05, 2004 9:04 pm
it depends if it's a 4 or 6 cyl.29 for the 4 and 32 for the 6
dawp
