SolaraGuy.com • View topic - 2005 gen2 are different?
Postby Willy7o2 » Mon Oct 04, 2004 8:43 pm
Found this info at Toyota's Website:
3.3-liter DOHC
24-valve VVT-i V6
225 hp @ 5600 rpm
240 lb.-ft. @ 3600 rpm
I thought I remember seeing the rpm was lower for max-hp ... and high rpm for max-torque. I remember seeing this info 6 months ago. Or am I wrong? They also dropped the V6 SLE down to $23600 for 2005? That was like $25900 6 months ago. Am I wrong on that too?
2004 Solara V6 SLE
TRD FSTB+RSB & Muffler
K&N High Flow Air Filter
Front GFX Lips
Mike T's Custom Grill Combo
Limo-Tint All Around
Willy7o2
Postby Shoe » Mon Oct 04, 2004 9:09 pm
on the canadian web site the price for an 05 sle has gone up
04 sle = $42647.75
05 sle = $42705.25
quite a difference for a car in canada eh?
shoe
Shoe
Postby TW85 » Mon Oct 04, 2004 9:15 pm
Engine specs are the same.
Moved on to better things...
TW85
Re: 2005 gen2 are different?
Postby slingshot » Mon Oct 04, 2004 9:22 pm
AZNBoYie02 wrote:
3.3-liter DOHC
24-valve VVT-i V6
225 hp @ 5600 rpm
If the torque is more important in 0-60 times than horsepower, is it better to shift at 3600rpm when using the tiptronic instead of higher? I've been shifting closer to 5000 rpm. Wondering if anyone did any time comparisons on shifting at higher or lower rpm's.
slingshot
Postby Lone Solara » Mon Oct 04, 2004 9:52 pm
AZNBoYie02 wrote: They also dropped the V6 SLE down to $23600 for 2005? That was like $25900 6 months ago. Am I wrong on that too?
The $23600 is for the I4 SLE. The V6 SLE starts at $26600. If you look under the Price tab, it lists all trims individually.
Lunar Mist Metallic
Dark Stone Interior
Black Top
K&N air filter
Lone Solara
Postby Lone Solara » Mon Oct 04, 2004 10:15 pm
slingshot wrote:
AZNBoYie02 wrote:
3.3-liter DOHC
24-valve VVT-i V6
225 hp @ 5600 rpm
My understanding is that the answer is NO, you should not shift at 3600rpm. The torque curve is probably at 90% and higher between a certain range (for example 3000rpm to 5500rpm), and while it is in our case the maximum at 3600rpm, it's close to that maximum probably anywhere between 3000rpm and 5500rpm (or redline). The downside of shifting at 3600rpm is that once you shift, your RPMs drop to around 2000rpm where you have very little usable torgue. However, if you shift at 5000-5500rpm, it will drop smack at the max of the torque at 3600rpm, right at the peak of the torque curve.
I realize this is not a particularly good explanation, so here's a link that I found on the net. I hope it helps:
http://www.allpar.com/eek/hp-vs-torque.html
Lunar Mist Metallic
Dark Stone Interior
Black Top
K&N air filter
Lone Solara
Postby rohand » Tue Oct 05, 2004 12:33 am
You know, I'm sure you're right. The website pretty much proves that you are. But with the tiptronic, I really don't think it makes that much of a difference. After all, it is an auto when it really comes down to it. Plus, my acceleration is a lot better when i shift into second around 3600, or a little lower. The shift is smoother and I feel more torque in 2nd. I'm not trying to say you're wrong or anything. I'm just putting my 2 cents in. I have no facts to back me up...I drive by feeling.
rohand
Postby Rudy » Tue Oct 05, 2004 12:52 am
physically there's no way you can accelerate faster shifting at 3600 than at 5000
99 Solara V6 5SPD
Rudy
