SolaraGuy.com • View topic - ECU Reset to New Tire Size?
Postby TW85 » Thu Oct 14, 2004 7:29 pm
I'm thinking of replacing the crappy OEM Bridgestones with Pirellis. The closest size to OEM the Pirellis come in is 225/45R17 which will make the speedometer read a little too fast. Can a Toyota dealer set the speedometer to accurately read with the new tire size?
Moved on to better things...
TW85
Postby Mole » Thu Oct 14, 2004 9:37 pm
the difference will be so miniscule that you will not notice the difference in speed.
have you thought other than pirelli?
Postby TW85 » Thu Oct 14, 2004 10:46 pm
Pirelli seems to be the best option from everything I've read. Nearly all reviews/tests are very positive and it (PZero Nero M+S) is more realistically priced than a comparable Michelin Pilot...
Why do you ask?
TW85
Postby Mole » Thu Oct 14, 2004 10:53 pm
oh nothing, just like to get a few other suggestions of tires that may not have the fitment issue.
Postby TW85 » Thu Oct 14, 2004 11:12 pm
The tires I found in the 215/55R17 size all seem to be equivalent to the OEM Bridgestones.
Are there fitment issues? It doesn't seem like it would be a problem to go to a 225/45R17...
TW85
Postby Mole » Thu Oct 14, 2004 11:24 pm
try hunting for 50 series tires, although there shouldnt be any fitment issues by going 45.
i hope you know that by going into lower series, the more road noise and less cushion you get while driving.
unless you are looking for slight steering response.
Postby DocJohn » Fri Oct 15, 2004 7:10 am
TW85 wrote:The tires I found in the 215/55R17 size all seem to be equivalent to the OEM Bridgestones.
I'm running 235/45R18's with no problems, so I can't see how you would encounter any problems with 225/45R17's.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby yanges » Sun Oct 17, 2004 3:52 pm
if you can get that size in a Yokohama tire i highly recommend them.... 8)
yanges
2004 Arctic Frost Pearl Solara SE
yanges
