SolaraGuy.com • View topic - Help... instructions to replace radio w/ oemvalue nav unit
Postby terrydf » Sun Oct 17, 2004 10:50 pm
I've ordered a toyota nav unit to replace my stock cd/radio unit. Can anyone direct me to insturctions about removal and replacement of dash panel pieces, etc?
terrydf
Postby slingshot » Sun Oct 17, 2004 11:10 pm
If you're installing it yourself, you'll have to also figure out where and how to install the GPS antenna. Do you have or are you getting a NAV install manual with it?
slingshot
Postby terrydf » Sun Oct 17, 2004 11:14 pm
I don't think it comes with an install manual, only an operating manual. But I could be wrong. Is it a bad idea for me to try this install? (I'm not a mechanic.) I was thinking the GPS antenna should go on the dash or behind the rear view mirror. Where does the factory put it?
terrydf
Postby slingshot » Mon Oct 18, 2004 5:33 am
terrydf wrote:I don't think it comes with an install manual, only an operating manual. But I could be wrong. Is it a bad idea for me to try this install? (I'm not a mechanic.) I was thinking the GPS antenna should go on the dash or behind the rear view mirror. Where does the factory put it?
No idea but it isn't anywhere visible. I'm guessing under the dash somewhere. I'd try to get a NAV install manual if possible if I was you. Sounds like you'd have to take apart at least the whole center panel area.
slingshot
Postby DocJohn » Mon Oct 18, 2004 5:46 am
You are correct, the GPS antenna is located under the dash.
This is a fairly complicated job. If the NAV system doesn't come with install instructions, I would probably let Toyota do the install.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby terrydf » Mon Oct 18, 2004 7:27 pm
Isn't the Toyota nav unit pretty much plug and play?
terrydf
Postby got sport » Tue Oct 19, 2004 12:15 am
How much and where from did you get the nav unit? And what model is your '04? I have the Sport, and I'm considering a nav.
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Postby terrydf » Wed Oct 20, 2004 8:22 pm
It's an 04 sle-v6 convertible. I ordered the unit from oemvalue.com. I was also hoping to hear from other's in this forum about their experience.
04 Solara Vert - SLE-V6 black on blue
terrydf
