SolaraGuy.com • View topic - Ride Quality After 10,000 Miles?
Postby TW85 » Mon Oct 18, 2004 2:22 pm
I have 11,000 miles on my car now and have noticed the ride is a little firmer and harsher (good thing, IMO). I remember someone mentioning the same thing but at the time most of us had less than 5,000 miles on our cars. Now with more mileage, have you noticed a change in the ride quality?
Moved on to better things...
TW85
Hey
Postby mmcdonald » Mon Oct 18, 2004 4:05 pm
I can't speak for the SLE owners. I have a Sport with 18K, and the ride is the same, except for the degredation due to the cheap-*ss tires.
My feeling is that once they are changed, the car will handle even better than new.
Perhaps that is where the ride issue lies.
You say it is "firmer." Is that "harsher?" Or a better firmer ride?
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
Postby TW85 » Mon Oct 18, 2004 5:12 pm
I guess what I meant is I now feel more of the road surface than I used to.
TW85
Postby got sport » Mon Oct 18, 2004 5:17 pm
I enjoy my ride the same when I first got it, and now I have my Sport lowered and with 24K miles.
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Re: Hey
Postby jsie » Mon Oct 18, 2004 5:27 pm
mmcdonald wrote:I can't speak for the SLE owners. I have a Sport with 18K, and the ride is the same, except for the degredation due to the cheap-*ss tires.
I definetely agree w/ mmcdonald. My original tires are practically dead at 5k (become very hard). I can't wait to worn out the threads to get a better replacement.
Artic Frost Pearl
2.4L I4 5-Speed MT
jsie
Postby TW85 » Mon Oct 18, 2004 5:42 pm
Maybe it is the tires. They've worn quite a bit (coin test says about 4/32" left) and will soon be replaced with Pirellis.
TW85
Postby junest » Mon Oct 18, 2004 7:47 pm
Right now I only have 3K, I'll let you guys know when I get up there. It rides stiffer now since it been lowered.
2004 Solara SLE V6 Convertible
Webpage
junest
super solara girl
super solara girl
Postby slingshot » Mon Oct 18, 2004 9:02 pm
junest wrote:Right now I only have 3K, I'll let you guys know when I get up there. It rides stiffer now since it been lowered.
How much stiffer did the ride get? If the ride from the factory was a 9 out of 10, what is it now?
slingshot
Postby junest » Tue Oct 19, 2004 10:39 am
A lot stiffer. I would say 15 out of 10 and 10 being the stiffest. It's off the charts. I went with the TRD spings.
Webpage
junest
super solara girl
super solara girl
Postby jsie » Tue Oct 19, 2004 11:09 am
I would say my suspension characteristic is pretty much the same. But now I believe this aging tires cause me to feel pretty much every gravel on the street; and the road grip is drastically reduced. Mine came w/ the Toyo tires; and if i will rate someting, I'll rate the tire's road grip which I would give 7 out of 10 when brand new and now at 7k I give a 3 or 4.
Artic Frost Pearl
2.4L I4 5-Speed MT
jsie
Postby slingshot » Tue Oct 19, 2004 2:58 pm
You misunderstood me. 10 out of 10 means the most comfy ride that isolates you from road surfaces- example: luxury car. The Solara is 9 out of 10 meaning pretty damn comfy ride. So the ride with your lowered TRD springs would be a lower number as you would feel every road joint. So what do you think this new number is?
slingshot
Postby got sport » Tue Oct 19, 2004 3:07 pm
Mine is still a 9.
got sport
Postby gogeta » Tue Oct 19, 2004 4:05 pm
i definitely feel more of the road as well....i have just about 10 thousand on it....still love my car though....
arctic frost pearl/gray 04 se
trd exhaust/air filter
mb quart 2 way 6x9s front
eclipse 4-way 6x9s rear
kicker kx 600.1/kicker l7 dual 2ohm
alpine head unit itching to be put in...
gogeta
Postby slingshot » Tue Oct 19, 2004 4:22 pm
got sport wrote:Mine is still a 9.
I wonder why Junest got a totally different result than you if you both used the TRD springs. Until your post, I had heard the springs worsen the ride quite a bit but make flat handling in turns better.
slingshot
Postby got sport » Tue Oct 19, 2004 4:26 pm
I'm assuming it's because I have the SE Sport with the Sport supsension.
got sport
Users browsing this forum: No registered users and 2 guests
