SolaraGuy.com • View topic - best headlight and fog light combo to go with?
Postby Arthur2k4 » Mon Oct 18, 2004 5:24 pm
i wanna change the lighbulbs for my head lights and fog lights..and maybe the high beams.. which woul dbe the best one to go with ... cant afford HID so best thing that cost less that that?
willing to spend aorund 80 bucks.. maybe a lil more
was thinking about getting the Silverstars...worth it?
Arthur2k4
Postby TS04 » Mon Oct 18, 2004 5:41 pm
Definatly Nokya's. Quality and High Temp Color. About 7000k. Long lasting. I don't use my High beams all that much and I'd shut them off if a car was coming anyways. I'm getting some. DocJohn did some testing even though the nokya's are 80watts. He said he's had them since July and no problem yet. Nokya Bulb Test
04 Solara SE Sport Coupe Black
35% Tint Sides, 20% Back
Clear Corners
Blue Illuminated Entry
Mike T' Black Combo Grills
TS04
Postby ICrazyChrisI » Mon Oct 18, 2004 6:43 pm
Stock.
ICrazyChrisI
Postby DocJohn » Mon Oct 18, 2004 7:07 pm
I'm very satisfied so far with the Nokya Arctic White H11 and 9005 bulbs (low & high beams) and the Hoen "All Weather" yellow H10's in my foglights.
I was very interested when I saw on the Hoen site that they will be selling Xenonmatch Vi 7 bulbs by late October. They describe these as follows:
"Using some components from the xenonmatch Titanium line the Vi 7 is optimized for projector lighting assemblies and operates at 70w. Available in H7, H11 and 9006. $69 USD per pair."
These are the first bulbs that I'm aware of that are available optimized for either projector (Xenonmatch Vi 7) or reflector (Xenonmatch Vi) applications. I'll probably try a pair of the Xenonmatch Vi 7 H11's eventually.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby Arthur2k4 » Tue Oct 19, 2004 5:07 pm
i didn't like the stock fogs... was al lil to yellow for me..so i replaced them with 9005 silverstars and now i have the head lights to do.. the Nokya Arctic White ones look tight...how much are they anyways? and do i have to order or do stores carry them too
Arthur2k4
Postby TS04 » Tue Oct 19, 2004 5:17 pm
Real HID's depend on the temp, but I think they usually go for around 200-300 dollars.
Clear Corners
TS04
Postby thealkimo » Tue Oct 19, 2004 6:48 pm
if u don't want to spend $$$ on hids...PIAA bulbs are a good alternative :wink:
thealkimo
Postby boaclub923 » Tue Oct 19, 2004 11:33 pm
i prefer 6000K~7000K HID, and keep fog light stock, maybe even change it to YELLOW. cause yellow color works the best in rainging/snowing days...
boaclub923
Postby Jewls » Mon Oct 25, 2004 11:01 am
ICrazyChrisI wrote:Stock.
I'm gonna have to agree. Stock lighting is already pretty superior to most other cars on the road. I am constantly getting high's flashed at me when my highs are not even on.
2005 Mustang GT Premium
2004 SE Black-SOLD
Pioneer MP3/XM radio/speakers,K&N filters,TRD RSB,Cargo Net,OEM Mud Guards,sport pedals, blue interior lighting,TRD oil cap,20% tint
Jewls
Postby rohand » Mon Oct 25, 2004 1:31 pm
Not to be a sheep, but stock are the best bulbs to go with. If you are looking for the best after-markets, I'm kinda partial to the Hoen Xenonmatch plus. They really look like HIDs from a distance and they actually are pretty bright. For fogs, Hoen All-Weather H10s. They may not be as yellow as you may want them to be, but they look badass and compliment the Xenonmatch pretty well. That reminds me; I should post a picture of them at night.
rohand
Postby Arthur2k4 » Mon Oct 25, 2004 4:45 pm
DocJohn wrote:I'm very satisfied so far with the Nokya Arctic White H11 and 9005 bulbs (low & high beams) and the Hoen "All Weather" yellow H10's in my foglights.
so the low beam ones are the h11 right? and where did u buy them from... i cant find them in the store.. do i have to order online?
Arthur2k4
Postby DocJohn » Mon Oct 25, 2004 5:49 pm
Yes, low beams are H11, high beams are 9005, and fogs are H10.
For Nokya Arctic White Stage II 9005's and H11's try:
H11's: http://www.eautoworks.com/ord-Auto~Acce ... -15725.htm
9005's: http://www.eautoworks.com/html/ORD-Ligh ... o-2660.htm
Other places sell these so shop for the best price.
Also, the stock bulbs on the Solara are quite good, but there are simply better AM alternatives like Hoen and PIAA. For example, the 55 watt Hoen H10 "all weather" (yellow) bulbs simply outclass the stock Sylvania 42 watt bulbs in all respects (except price).
DocJohn
Postby Arthur2k4 » Mon Oct 25, 2004 7:42 pm
umm.. i have 9005st on my fogs....thats the one they gave me at the store..been working good...is that gonna be a prob?
Arthur2k4
Postby DocJohn » Tue Oct 26, 2004 6:07 am
I didn't know that a 9005 bulb could fit in an H10 socket without modification. :o This is very interesting. Anyway just know that the 9005st is a 70 watt bulb and you are using it in a housing designed for a 42 watt bulb. The Hoen H10 fogs I'm using now are 55 watts and everything has been fine so far. As long as your foglight housings can handle the additional heat, you should be okay.
EDIT: OOPS! :oops: I just checked and the 9005 (or HB3) bulb base IS interchangable with the H10 (or 9145). The H10 bulb was developed on the 9005 platform. See:
http://www.donsbulbs.com/bulbs/g/b/p20d.gif AND
http://www.gelighting.com/na/downloads/techsheet.pdf
However, the info on the increased wattage of the 9005 over the H10 is correct.
DocJohn
