SolaraGuy.com • View topic - TSB for sunroof actually works!!! I have proof....
Postby mattyboyl » Mon Nov 08, 2004 12:41 pm
I, like many others, here have had that terrible rubbing sound when opening and shutting the sunroof. Toyota has replaced the motor and tracks with no success. With the TSB, it calls for replacing the sunroof glass. I know what you're thinking. I figured, what do I have to lose? It probably won't work, but I need an inspection anyway. So they performed the TSB. The car was sitting out in the sun waiting for me to pick it up. I get in and expect to hear the noise, and let me tell you, I was shocked! The sunroof was quieter than ever. Very smooth and I couldn't hear a sound. It was very smooth, the way it should of been brand new! I was still alittle pessimistic and tried again later and again today at differnt times a day because I've never gone a full day wityhout hearing it. This is solution does work somehow. Now, a solution for thos edamn rattles and we'll be good.
mattyboyl
Postby Shoe » Mon Nov 08, 2004 1:21 pm
what were they using b4 expandable glass? strange fix but hey what ever works eh
good stuff matt
shoe
Shoe
Postby Aotoyota » Mon Nov 08, 2004 8:28 pm
how to u go about approaching them to correct the problem with a TSB? did u bring in a list or did they just do it?
Aotoyota
Postby mattyboyl » Tue Nov 09, 2004 9:01 am
Aotoyota wrote:how to u go about approaching them to correct the problem with a TSB? did u bring in a list or did they just do it?
Actually, I knew about the TSB prior. SO when I went in, I informed them of the problem and they just told me they were replacing the sunroof glass. So, they were aware, but all Toyota's aren't the same. Come in prepared.
mattyboyl
What is the TSB number for the sun roof problem?
Postby Joel » Sat Nov 13, 2004 8:13 pm
Do you have the TSB number for the sun roof problem? I did not see it in the list at Alldata (I have the 2004, SLE, V6). I have had my Solara in the shop twice for the problem, with no success in getting it fixed.
Thanks!
Joel
Joel
Postby mattyboyl » Sun Nov 14, 2004 12:42 pm
Here you go:
http://www.zer0.info/solaraguy/viewtopi ... 3a0609d8d1
This also has other TSBs you may be experiencing.
mattyboyl
Postby sleeper solara » Wed Nov 17, 2004 11:32 am
hey im new here. im also experiencing this problem. so i just go to the dealership and tell them to replace the glass?? also..what does TSB stand for? :oops: so yea...thanks guys
Fabulous
May she rest in peace.
November 19, 2003 - March 4, 2005
She gave me her all and never complained.
I will remember her always.
sleeper solara
Postby michaels artic frost » Wed Nov 17, 2004 11:54 am
sleeper solara wrote:hey im new here. im also experiencing this problem. so i just go to the dealership and tell them to replace the glass?? also..what does TSB stand for? :oops: so yea...thanks guys
TSB - Transportation Safety Board
Updated 06/01/12: Michael T's
Postby sleeper solara » Wed Nov 17, 2004 12:40 pm
thanks michael...haha im the dude that emailed u the other day about getting started with sponsors :)
Fabulous
sleeper solara
Postby Lone Solara » Wed Nov 17, 2004 7:29 pm
Of course, some dealers may be more familiar with the context specific translation of Technical Service Bulletin ...
Lunar Mist Metallic
Dark Stone Interior
Black Top
K&N air filter
Lone Solara
Postby xodessitx » Fri Apr 08, 2005 4:41 pm
i have had the same rubbing noise with the sunroof being open. Tehy replace the glass and at first it was fine, but now i have the same issue again. the roof makes this terrible noise whenever i open it. any idea on what i can do to fix it?
2004 solara
se sport v6
lunar mist
getting tints probably 20% all around
more coming soon.....
xodessitx
Postby Buckeyegirl » Sat Apr 09, 2005 1:10 pm
xodessitx wrote:..... but now i have the same issue again. the roof makes this terrible noise whenever i open it. any idea on what i can do to fix it?
Ditto!
Buckeyegirl
Postby redsle » Tue Apr 12, 2005 3:31 pm
I found out there are 2 TSB's for the sunroof noise, the one reference on here, calls for replacing the sunroof glass. which my dealership did and the noise went away for about 2 weeks and then came back. The 2nd TSB (Number: NV004-05) calls for replacing the Cable Sub-assembly, Sliding Roof Drive (Part No: 63205-0E010) this is what acutally fixes it. So have your service advisor pull up this TSB and do it on the car and you will not have any more problems, be prepared to leave the car for the day, as they have to take off the headliner and take out the sunroof motor to replace the cable assembly. My dealership gave me a loner car for the day, ask yours they might do that for you also. Hope this helps.
2004 SLE Red/Gray Leather
MudGuards
TRD Air Filter
redsle
Postby Buckeyegirl » Wed Apr 13, 2005 5:14 am
redsle wrote:I found out there are 2 TSB's for the sunroof noise, the one reference on here, calls for replacing the sunroof glass. which my dealership did and the noise went away for about 2 weeks and then came back. The 2nd TSB (Number: NV004-05) calls for replacing the Cable Sub-assembly, Sliding Roof Drive (Part No: 63205-0E010) this is what acutally fixes it. So have your service advisor pull up this TSB and do it on the car and you will not have any more problems, be prepared to leave the car for the day, as they have to take off the headliner and take out the sunroof motor to replace the cable assembly. My dealership gave me a loner car for the day, ask yours they might do that for you also. Hope this helps.
Yeah, I had the sunroof replaced with the glass panel also. Thanks for 2nd TSB for Cable Sub-assembly. Hopefully this will fix it once and for all.
Buckeyegirl
haha
Postby mmcdonald » Fri Apr 15, 2005 9:48 am
Transportation Safety Board, haha, good one... :lol:
Let us know what the delaer says about that... :lol:
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
