SolaraGuy.com • View topic - Is 5th gear on sport drive bad fuel efficiency?
Postby vishnuna » Thu Nov 18, 2004 11:30 am
I have a v6 Sle solara and was wondering if the fuel efficiency when I switch it to the 5th gear on the sport shifter, would it be the same as that on regular conditions.
I understand that for the other gears it will surely be lower.
vishnuna
Postby boaclub923 » Fri Nov 19, 2004 2:33 pm
um, i personally believe it will consume more gas; however, ppl in this forum done the test, they said it makes no different.
i forget which post they discusss it exactly, but i remember it was talking something about to solve lagging tranny problem.
boaclub923
Re: Is 5th gear on sport drive bad fuel efficiency?
Postby angelo » Fri Nov 19, 2004 3:59 pm
vishnuna wrote:I have a v6 Sle solara and was wondering if the fuel efficiency when I switch it to the 5th gear on the sport shifter, would it be the same as that on regular conditions.
I guess the fuel efficiency depends most on how you step on the gas pedal - I do not find any difference between S5 and D...
angelo
