SolaraGuy.com • View topic - 2004 TSBs fixed for 2005 solara v6?
Postby sportscarguy » Sun Nov 28, 2004 8:32 pm
have all the 2004 TSBs issued for the solara been fixed for the 2005 solara? any of you 2005 owners experienced throttle lag or rattles?
does any 2004 owners know if the TSBs have been fixed for 2005?
sportscarguy
Postby technole » Mon Nov 29, 2004 11:21 am
Yeah, all the issues that were sporadic in the 2004s have been fixed coming off the line in the late 2004 and just-released 2005 models.
2004 Solara V6 SLE w/XM Satellite Radio
technole
Postby slingshot » Mon Nov 29, 2004 12:46 pm
technole wrote:Yeah, all the issues that were sporadic in the 2004s have been fixed coming off the line in the late 2004 and just-released 2005 models.
Can you reveal your source for this?
slingshot
Postby technole » Tue Nov 30, 2004 9:27 am
A friend of mine at a dealership mentioned so.
technole
Postby billabong021 » Tue Nov 30, 2004 10:32 am
Everything on my 2005 V6 Sport has been fixed, except for the reaer deck rattle which is very annoying.
billabong021
Postby slingshot » Tue Nov 30, 2004 12:27 pm
billabong021 wrote:Everything on my 2005 V6 Sport has been fixed, except for the reaer deck rattle which is very annoying.
I had an annoying rear deck rattle and brought it in to the dealership. They added more padding to it and said the factory must not have put enough. Tell your dealer to do the same to fix it.
slingshot
2004 tsb corrected in 2005 models
Postby jig47 » Tue Nov 30, 2004 6:51 pm
I beg to differ with some of the previous posters. I have a 2005 v6 sle and it has all of the above mentioned problems, i.e. throttle lag, thumping in rear suspension, and numerous plasticy rattles, ticks, etc. Your dealer contact is full of $hit.
jig47
Re: 2004 tsb corrected in 2005 models
Postby slingshot » Tue Nov 30, 2004 8:55 pm
jig47 wrote:I beg to differ with some of the previous posters. I have a 2005 v6 sle and it has all of the above mentioned problems, i.e. throttle lag, thumping in rear suspension, and numerous plasticy rattles, ticks, etc. Your dealer contact is full of $hit.
I figured as much. There was at least one other 2005 owner with some of the problems. No certainty all problems are fixed in the second year of any car though they should be. Have you brought your car in to get the dealer to fix these problems yet? What was the outcome? I don't have the problems you mentioned with my '04 but have a left drift at highway speeds if I let the steering wheel go.
slingshot
Postby technole » Tue Nov 30, 2004 11:17 pm
The Throttle Lag isn't an "issue". Its the drive-by-wire and the shifting, people who have an RX330 sometimes complain about it.
Sounds like you got what I call a lunch hour car.
I mentioned only TSBs, none of those are across the board problems except the rattle in the rear deck, i got more padding back there and i still get a little rattle.
technole
Postby jig47 » Wed Dec 01, 2004 3:03 pm
I brought it in for the rear end thumping and they had the car for 3 days. When I got it back they claimed everything checks out fine and they all do this. Also, I mentioned the rear rattle sounds and they took out the rear deck and taped it. I think the problem is the headliner or maybe this car is just a POS. My long term goal is to bring the car in 2 more times for the thumping sounds and file a lemon law complaint. (hopefully Toyota is reading this post). :oops:
jig47
Postby TW85 » Thu Dec 02, 2004 12:20 pm
If someone tore apart the rear of my car they would laugh at the amount of foam padding I have stuffed in where I can reach. I found the rear rattle to be the headliner.
Now if I could find the frickin' rattle that is coming from in the front driver's side dash area... :x
Moved on to better things...
TW85
Postby sportscarguy » Fri Dec 03, 2004 12:31 am
i just got my solara and notice there is a little bit of thumping sound coming from the back on certain bumps.....sthis may sound stupid, but what part is the headliner? where are you putting the foam in. please describe, thanks
sportscarguy
Postby jig47 » Tue Dec 07, 2004 7:58 pm
sportcarguy: the rear end thump noise and the headliner noise are not the same noise. The thump has to do with the suspension and the headliner (the liner over your head extending to the rear window) has to do with with poor body panel plastic clips. Some people stuff foam in the gaps to minimize eliminate the ticking/rattles the headliner can make.As far as the thump goes, I hope you get to learn to like it as so far Toyota is not offering an official fix. Member Falaniz is the only person I know of that claims to have gotten the dealership to resolve the problem.
jig47
