SolaraGuy.com • View topic - Another problem... do you have it?
Postby truebluestang » Mon Dec 20, 2004 8:25 am
Well, my washer jets aren't working at all. Not sure if they are frozen or not, but I've tried everything I can think of. It started yesterday when the temperature was at 2 degrees. I got some more fluid (which is de-icer, so I would assume that it shouldn't freeze right?). I drove for about 2 hours straight, and they still didn't work which is annoying. If you're from Michigan, and probably any other cold weather state, you know that when it snows, the snow, dirt and salt all mix together for a wonderful concoction of paste that is impossible to remove from your windows without washer fluid. If your jets don't work, your window will literally cake with the stuff to the point that you can't see. So you can see why this is a problem. Just wondering if anyone else is having this problem. I've never had this problem on any car that I've ever owned.
2003 Ford Mustang
Cervinis Stalker Kit
Eibach Sportline Lowering Springs
2004 Toyota Solara SE Sport.
truebluestang
Postby Jai_Jai_Binks » Mon Dec 20, 2004 9:42 am
if your lines are already froozen, then your SOL. I'm guessing your added teh de-icing fluid after your lines are froozen...I had my celica lines froozen when i didn't have the de-icer washer fluid (just the reg washer fluid)! i literally waited for a warm day and finished my washer tank.....(yeah, i took really smart washing my windshield for 3-4 minutes....) but in the end i know next time to be prepared for a wisconsin winter by filling the de-icing fluids in early november!
Postby Mole » Mon Dec 20, 2004 10:04 am
wow! 2 degrees!
in that weather, if you spit, will it freeze before it touches the ground?
about your washer squirters, you sure its not plugged up by wax?
Postby Shoe » Mon Dec 20, 2004 11:25 am
you havent been fiddling withthe fuses have you?
I actually blew the fuses on the cigarette lighter with an inflator pump taht i tried to rewire i didnt do taht great of a job and it blew the fuses. To check that i used the washer fuse wich was teh same type but when i put the washer fuse back in to the spot it said the washer fuse didnt work either i re checked where i put it and moved it up 1 and it worked the diagram on the cover was actually wrong.
if you didnt move the fuses maybe you blew the fuse?
shoe
Shoe
