SolaraGuy.com • View topic - What grade gas do you run
what grade do you use?
87
30
50%
89
16
27%
93
14
23%
Total votes : 60
Postby truebluestang » Wed Dec 22, 2004 8:59 am
and what kind of mileage do you get?
I was running 93 strictly from BP, but decided to drop it down to just regular to see if what I thought about mileage on higher gas is true. I get about 80 more miles out of a tank on 93 than I do on 87.
2003 Ford Mustang
Cervinis Stalker Kit
Eibach Sportline Lowering Springs
2004 Toyota Solara SE Sport.
truebluestang
Postby Shoe » Wed Dec 22, 2004 9:30 am
Just 2 options?
I think you forgot to hit enter after the 93 ( make the mistake myself)
I really hate to tell ya this but...
http://www.zer0.info/solaraguy/viewtopi ... hlight=gas
and then
But alot of this talk was done "back in the day"
shoe
Shoe
Postby truebluestang » Wed Dec 22, 2004 9:36 am
I figured when it came out that it was talked about who would run what, but didn't think anything would come of it. I did enter 93, but didn't hit the "add" button, so it didn't make it on there. I'm just curious because of the huge difference I"m getting between the grades. I just need to sit down and do the math and see if it's worth paying the extra .20 for premium.
2003 Ford Mustang
truebluestang
Postby Mole » Wed Dec 22, 2004 11:07 am
the higher the octance, the better the response,
however the higher the octane, the worse gas mileage you get.
Postby truebluestang » Wed Dec 22, 2004 12:24 pm
Mole wrote:the higher the octance, the better the response,
Are you sure about that??? The only thing I've done is change my octane to a lesser, and I get far worse mileage.
2003 Ford Mustang
truebluestang
Postby Mole » Wed Dec 22, 2004 6:10 pm
almost positive.
observe what happens when you use 100oct, vs 91 or 93 oct.
Postby rohand » Wed Dec 22, 2004 11:24 pm
I don't think so man. You get better gas mileage with higher octane. I always got better mileage in my 00 Camry with 89 or 91 as opposed to 87.
rohand
Postby Aotoyota » Thu Dec 23, 2004 6:11 am
i agree with rohand. my 00 sentra got about 3mpg more with 89 and had way better response. i use 87 in the solara now because its cheaper and im stuck in traffic most of the time.
Aotoyota
Postby truebluestang » Thu Dec 23, 2004 9:27 am
From the way I understand it, the higher octane burns cleaner, leaving less residue etc in the fuel system which increases MPG.
2003 Ford Mustang
truebluestang
Postby Mole » Thu Dec 23, 2004 11:15 am
perhaps this does not include the usage of 100oct.
please, try 100oct (race fuel if you dont know) and record your mileage.
your mustang will thank you. it is expensive, but its worth the try.
Postby GReddySetGO » Thu Dec 23, 2004 12:50 pm
You guys are all wasting your money. Higher octane will not give you better performance or better gas mileage. Octane is used to measure 1 thing and 1 thing only, the fuel ability to resist pre-ignition. This means higher octane fuel is actually harder to burn than lower octane. All the rest of the stuff is in your head. Next time have your friend buy gas for you and not tell you which grade, do this for 3-5 tanks. I bet you won't be able to tell which grade it was.
Danny
AIM: GReddy EVO Si
Forced Fed @ 20 psi
GReddySetGO
Postby Mole » Thu Dec 23, 2004 1:46 pm
so then, why do i get way lower mileage if i were to use 100 oct, vs 91 oct?
wont higher grade gas prevent knock/ping better than lower grade?
Postby Hsakuragi » Thu Dec 23, 2004 2:15 pm
Hsakuragi
