SolaraGuy.com • View topic - steering problem
steering problem
steering problem
Postby xodessitx » Fri Dec 24, 2004 2:06 pm
all of a sudden some wierd noises have been coming from the steering wheel, when i turn the wheel it makes cliking sounds and its not the same sound when u have ur turning signal tuurned on, and when u turn it snaps. have any one ever experienced such a problem?
2004 solara
se sport v6
lunar mist
getting tints probably 20% all around
more coming soon.....
xodessitx
Postby Jewls » Fri Dec 24, 2004 2:10 pm
Check the level of your power steering fluid, it could be low. My old car would make noises when I turn because it had a leak, once I replaced the fluid (and fixed the leak), it was fine.
2005 Mustang GT Premium
2004 SE Black-SOLD
Pioneer MP3/XM radio/speakers,K&N filters,TRD RSB,Cargo Net,OEM Mud Guards,sport pedals, blue interior lighting,TRD oil cap,20% tint
Jewls
Postby xodessitx » Fri Dec 24, 2004 2:22 pm
i have cheked the fluid its fine
its not always there but it appers afetr u drive for a while
2004 solara
se sport v6
lunar mist
xodessitx
Definately internal?
Postby Down2TheC » Tue Dec 28, 2004 9:58 am
If you found it, let us know what it was, pls. In the meanwhile... Is it from the guts of the steering or actually eminating from the steering wheel itself? (the clicks that is.) I've seen stuff jammed in the steering column that only rubbed or clicked when it warmed up and expanded. I can peek at the repair manuals after work but they've been pretty lame for me thus far.
Down2TheC
Re: steering problem
Postby DocJohn » Wed Dec 29, 2004 7:44 am
xodessitx wrote:all of a sudden some wierd noises have been coming from the steering wheel, when i turn the wheel it makes cliking sounds and its not the same sound when u have ur turning signal tuurned on, and when u turn it snaps. have any one ever experienced such a problem?
OH YES!! I had this EXACT same problem as you describe it. See my thread at:
http://www.zer0.info/solaraguy/viewtopic.php?t=10099
I had to go through hell trying to get Toyota to fix it, as my clicking at first was intermittent and didn't happen every time I turned the wheel. It finally got worse and the clicking occurred every time I turned the wheel. Toyota finally located the problem and replaced the spiral cable assembly in the steering column and this has appeared to solve the problem now.
Let me know if you need more info and I hope the repairs go smoothly. Once you get your car to Toyota, please post a follow-up and let me know if they came up with the same diagnosis and fix as I described. THANKS.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
