SolaraGuy.com • View topic - Spare Tire
Spare Tire
Spare Tire
Postby TS04 » Fri Jan 14, 2005 4:04 pm
Spare Tire: I got my tire slashed by a pot hole. Had to change out the tire to the spare. About how long can the spare be on there?
04 Solara SE Sport Coupe Black
35% Tint Sides, 20% Back
Clear Corners
Blue Illuminated Entry
Mike T' Black Combo Grills
TS04
Postby Shoe » Fri Jan 14, 2005 5:52 pm
id get it fixed as soon as possible if you have the donut spare.
The spare tire shouldnt be driven on at hwy speeds ( remeber reading this in my accord manual) and why risk running down the spare? Get the tire replaced and put that spare back in the trunk so you can use it again no sence having to buy 2 tires in the event that you ran down the spare.
That and it looks horrible its got no rim and its smaller ewwwwwww.
shoe
Shoe
Postby Mole » Fri Jan 14, 2005 6:50 pm
is the tire a donut or a full?
if full- then you can drive normal.
if donut- make sure you inflate to what the recommended psi is and do not go over 55mph.
Postby Arthur2k4 » Sat Jan 15, 2005 1:03 am
oh yea dont try any doin any burnouts with it either
Arthur2k4
Postby Yanks0114 » Sat Jan 15, 2005 12:25 pm
also with a donut you aren't supposed to drive more than 50miles
I'm pretty sure you should have a full size spare in which case you'll be fine
Postby online » Sun Jan 16, 2005 1:00 pm
If you have the spare on the front either replace it asap or move it to the rear. You should never run a psuedo spare (donut) on the front with front wheel drive...
2005 SLE Convertible
Absolute Red - Black Top
Nav System
K & N Filter
Mud guards
online
Postby gogeta » Sun Jan 16, 2005 8:19 pm
i dunno....i ran mine from kennebunk maine to boston mass...actually further south than boston....avg mph according to the car was 63...on the highway never went below 75.....not sayin its ok...but i did it and my doughnut is fine...
arctic frost pearl/gray 04 se
trd exhaust/air filter
mb quart 2 way 6x9s front
eclipse 4-way 6x9s rear
kicker kx 600.1/kicker l7 dual 2ohm
alpine head unit itching to be put in...
gogeta
