SolaraGuy.com • View topic - tire spin
tire spin
tire spin
Postby gogeta » Mon Jan 31, 2005 5:51 pm
i have kinda a heavy foot...mostly off the line....but lately when i shift into 2nd or 3rd...my tires are spinning....i always drive in sport mode...and this has never happened before...do u think its just the crappy stock tires...or am i needing to bring the car to the shop....ne and all input appreciated...
arctic frost pearl/gray 04 se
trd exhaust/air filter
mb quart 2 way 6x9s front
eclipse 4-way 6x9s rear
kicker kx 600.1/kicker l7 dual 2ohm
alpine head unit itching to be put in...
gogeta
Postby mattyboyl » Tue Feb 01, 2005 7:22 am
Impressive, but not normal. Are you flooring the car? Are the tires worn? There is something up, because that is not normal in an automatic tranny. You can do that to any manual with bad clutch techniques. :lol:
mattyboyl
Postby gogeta » Tue Feb 01, 2005 3:16 pm
definitely not flooring it....i usually shift between 3000 and at most...when i'm not screwing around...3500rpms.....and the tires spin when im not playin....
gogeta
Postby mattyboyl » Thu Feb 03, 2005 7:00 am
That's definitely not normal. I mean, that';s not even enough rpm's to spin cheap tires. Sound s the like the tranny may be slipping. Definitely get that checked out ASAP while you have the warranty.
mattyboyl
