SolaraGuy.com • View topic - Navigation/Radio Volume Quirk
Postby cklinh » Mon Feb 21, 2005 9:59 pm
Hi All,
I just installed my HID today, in the process I disconnected the battery. When I plugged it back in, the Nav/Radio started acting funny. The maximum volume (63) is still way low. It's like the radio is set at 20-something, but the screen says max. Also, it's not recognizing the ipod adapter (cd changer port).
Is there something I was supposed to do to reset the radio? Or has anyone had the same problem and how did you solve it. (I figure this may be similar to reseting the automatic window roll down, but I don't know)
cklinh
Postby boaclub923 » Tue Feb 22, 2005 12:53 am
um, i don't really know the problem,
but did u check the fuse?
fuse for stereo/amp?
boaclub923
Postby cklinh » Tue Feb 22, 2005 8:56 am
hm... that might explain the low volume (blown fuse for amp)... but not recognizing the ipod?
cklinh
Postby cklinh » Tue Feb 22, 2005 10:15 am
Just in case the problem is a fuse... anyone know where to look? under the hood? on the actual amp?
cklinh
Postby boaclub923 » Tue Feb 22, 2005 7:33 pm
hum... sorry.. me out of twon now,
i don't have car with me, can't tell u where to dig fuses.
but i will try the fuse box inside of car 1st~
boaclub923
Postby cklinh » Wed Feb 23, 2005 3:39 pm
OK... so I looked in my fuse box shortly (it was too dark to see anything...) and there were some that I couldn't figure out... anyone know what the following fuse labels mean? (they're written on the fuse box cover)
"AM"
"CDS"
"HEAD"
HOPING one of these (or another) is for the amp...
cklinh
Postby cklinh » Thu Feb 24, 2005 7:44 pm
I figured out what it was... something happened with my ipod adapter thing and it's screwing up... (wouldn't recognize it as a cd changer). took it out and volume came back up...
now i gotta figure out if that's the reason why my battery has been draining as well... gosh, i hope it's not the HID's that is causing the battery drain... (2nd time in three days i can't start my car).
cklinh
Postby online » Sat Feb 26, 2005 8:06 am
Since the volume returned to normal after removing the iPod adapter my guess would be that it is possible that there is an issue with the adapter.
Sounds like the adapter may be causing a short which would draw addtional current which leads to draining the battery. There is always the possibility that what you are plugging the adapter into could be the root cause of the issue.
2005 SLE Convertible
Absolute Red - Black Top
Nav System
K & N Filter
Mud guards
online
