SolaraGuy.com • View topic - Bad traction
Bad traction
Bad traction
Postby cs1044 » Wed Mar 02, 2005 5:26 am
I don't know if this only happens with my car, but everytime I floor the gas from a dead stop, the wheel spins for a while and then grips the road. It's even worse on uphill when I try to accelerate hard from a stop. Has anyone noticed this? Could this be fixed with better tires?
cs1044
Postby RichD978 » Wed Mar 02, 2005 5:39 am
y do you floor the gas from a dead stop?
RichD978
Postby cs1044 » Wed Mar 02, 2005 5:54 am
Well, I would floor the gas from a dead stop for fun mostly... Like to beat the car on the other lane on a stop light ;-)
But sometimes I have to floor the gas to merge the traffic... Unfortunately, there is one stupid area on my commute where I have to stop and yield to merge the traffic, and they are usually going 50+ MPH...
cs1044
Postby RichD978 » Wed Mar 02, 2005 6:51 am
im not sure but i think that happens because the car is light? i have a 99 and when i first bought it the same thing happened once. i just stopped... i step on the gas slowly for a couple seconds before i floor it (only entering highway)
RichD978
Postby Parke10 » Wed Mar 02, 2005 8:42 am
1. the car is not light , or even close to that
2.V6 for sure idk about 4cyl will spin the tires cuz yer sendin so much power all at one time, if u wanan accel but not spin dont floor it till like 10-15 mph
Parke10
Postby Parke10 » Wed Mar 02, 2005 8:44 am
1. the solara is not a lightweight car , or even close to that
Parke10
Postby cs1044 » Wed Mar 02, 2005 8:57 am
Is spinning common in most fast cars? Will it still spin even if I get better tires? Before my 2004 Solara, I was driving a weak 1990 Civic, so this is new to me.
cs1044
Postby mattyboyl » Wed Mar 02, 2005 11:13 am
Performance tires will greatly decrease if not eliminate your wheel spin. I would recommend not flooring it and your tires will grip just fine. If you keep spinning your tires, you'll end up like me with two almost bald tires up front and two brand new ones in the the rear.
mattyboyl
Postby Down2TheC » Wed Mar 02, 2005 1:18 pm
My SLEV6 G2 spins if I gun it (after the hesitation) depending on the surface. Cold smooth blacktop is a constant. Wait 'til summer and it'll happen less. I gotta go with Parke10. I get a fine push with no hesitation when I feather it in for the first 10 mph then floor it. And hey... rotate those tires!
Down2TheC
Postby boaclub923 » Wed Mar 02, 2005 2:12 pm
tires spin when car is taking off..
that's mean engine out put is TOO BIG for the tires at that moment...
change the tires could slightly improve but not significantly..
if u want significantly improve, then u need to put some tires with not grip on it...
which is very danger..
just don't hit ur gas that hard, it waste ur gas and make pollution...
boaclub923
Postby Parke10 » Thu Mar 03, 2005 12:23 am
like i said and evryone is saying 2 much instant power to the wheels just dont gun it, if u wanna car that u can gun and have no wheel spin, buy an AWD car
Parke10
Postby boaclub923 » Thu Mar 03, 2005 10:04 am
Parke10 wrote:like i said and evryone is saying 2 much instant power to the wheels just dont gun it, if u wanna car that u can gun and have no wheel spin, buy an AWD car
oh!! u know what, i get a better idea... go buy echo/xA/xB...
i think it can solve the problem~
boaclub923
Postby Parke10 » Thu Mar 03, 2005 11:13 am
even the xB will spin em
Parke10
Postby Mandarinsolara » Thu Mar 03, 2005 8:08 pm
mattyboyl wrote:If you keep spinning your tires, you'll end up like me with two almost bald tires up front and two brand new ones in the the rear.
im all too acquainted with this problem
i promise if you hit the gas in a linear motion instead of all at once then you should be fine. and i think thats kind of wild if you feel that you must floor it.
Mandarinsolara
