SolaraGuy.com • View topic - change new tire & mph
Postby qhoc0010 » Sun Mar 20, 2005 11:44 pm
Now I have 17". If I change to 19", the speedometer will not show correctly. How to fix that?
Also, do I need to buy a new spare tire too if I buy a whole set of 4?
qhoc0010
Postby dawp » Mon Mar 21, 2005 3:52 am
it depend on tire size,it can adversly affect your speedo and show either to fast or to slow.it can be tricky to get the right size so the diamater is the same as the oem wheels.
as far as spare,depend if u buy a set of 5 rims.
dawp
Postby zappa » Mon Mar 21, 2005 5:00 am
As Dawp said it depends on the tire size. If you have a later model Solara with 235/50-17's you'd need a 225/40-19 to keep within +/- .04 in. of original tire diameter.
zappa
Postby DocJohn » Mon Mar 21, 2005 7:25 am
Actually if you have a Gen 2 (04-05) Solara with 17" wheels, your stock tire is a 215/55-17, so to minimize speedo error with a 19" wheel use a 235/40-19 tire (gives you only a -0.3% speedo error).
See this link to check it for yourself: http://www.miata.net/garage/tirecalc.html
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby qhoc0010 » Mon Mar 21, 2005 8:14 am
DocJohn wrote:Actually if you have a Gen 2 (04-05) Solara with 17" wheels, your stock tire is a 215/55-17, so to minimize speedo error with a 19" wheel use a 235/40-19 tire (gives you only a -0.3% speedo error).
Yep, that is my plan. Thanks.
qhoc0010
Postby Astro » Mon Mar 21, 2005 9:14 am
Get some dubs!
