SolaraGuy.com • View topic - questions to owners with 20 inch rims
Postby Solara08861 » Mon Mar 28, 2005 10:08 am
How many pounds of pressure you have on your tires?
I have 225/35/20 with 30lbs is that correct?
Can we reset the tire pressure indicator on the dash to monitor the 20's
Solara08861
Re: questions to owners with 20 inch rims
Postby Mole » Mon Mar 28, 2005 12:44 pm
Solara08861 wrote:How many pounds of pressure you have on your tires?
that is low. too low.
Postby DocJohn » Mon Mar 28, 2005 6:21 pm
My best guess is 35 to 40 psi for these.
Yes, if you reset the pressure monitor system, it should work okay with your 20's.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby mikei » Mon Mar 28, 2005 10:11 pm
When I had my 18" TRD Wheel and tire set installed at a TRD
authourized Dealer the TRD technician said to never run less than
40 lbs.
in the Michelin Pilot Sports. He said running under 40 lbs. will
lead to 1.) premature tire wear on the outside tread
2.) rim damage
I am sure that this line of thinking applies to your setup as you are
running an even lower profile tire than me.
2005 Solara SLE V6 Convertible-Silver
VSC/TRAC/NAV/XM Sat/Mudflaps/Clear license plate covers/Bug deflector/Glass breakage sensor/SS Door Sills/Eclipse backup camera
Japan voice-mic/Everything TRD
mikei
Postby michaels artic frost » Thu Mar 31, 2005 5:45 am
I've got mine set for 45 psi with 245/35/20. :D
Updated 06/01/12: Michael T's
psi in tires for 20" rims
Postby EPADEMIK » Mon Apr 04, 2005 1:01 pm
I run 36 psi on mine. If you run too much air in your tires you will go thru tires like nothing.
EPADEMIK
Postby Solara08861 » Mon Apr 04, 2005 1:04 pm
My tires are 245/35/20.
The place that did my alignment put them at 40
Solara08861
