SolaraGuy.com • View topic - adjusting headlight
adjusting headlight
adjusting headlight
Postby ndoyank » Sun Apr 03, 2005 1:58 am
Does anyone know how to adjust the height of the headlight? The beam of my headlight is quite high so I wanted to lower it a bit.
Any help would be appreciated.
18' volks, TRD RSB, TRD FSTB, TRD springs, HID retrofit. Micheal T's Grille ..... Silver ICE
ndoyank
Re: adjusting headlight
Postby DocJohn » Mon Apr 04, 2005 7:22 am
ndoyank wrote:Does anyone know how to adjust the height of the headlight? The beam of my headlight is quite high so I wanted to lower it a bit.
Yes, I do. PM me your e-mail address and I will send you the PDF from the service manual with the headlight alignment procedures.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby xcgames » Wed Jun 01, 2005 6:09 pm
bump...
I'm having a similar problem, except my lights are way too low and it doesn't light up anything at night. Can i also have a copy of the manual? thanks a bizillion!
xcgames
Postby slingshot » Wed Jun 01, 2005 8:14 pm
Shouldn't that be fixed under warranty? Sure sounds like they both came bad from the factory.
slingshot
Postby Eviltwinpsu » Thu Jun 02, 2005 6:24 pm
yea it should be...but why take something to the factory that you could easily do at home....
Eviltwinpsu
