SolaraGuy.com • View topic - Toyota addresses 'hesitation' concerns with new software
Postby technole » Mon Apr 11, 2005 11:36 pm
2004 Solara V6 SLE w/XM Satellite Radio
technole
Postby Buckeyegirl » Tue Apr 12, 2005 9:23 am
That's great, Thanks!
Buckeyegirl
Postby sgunitkc » Tue Apr 12, 2005 10:08 am
So is that mean if you have automatic you can just take it into a dealer for the upgrade? that simple?
sgunitkc
Postby mattyboyl » Tue Apr 12, 2005 1:05 pm
Good question. Would be interested to see anyone try this and give us the result.
mattyboyl
Postby redsle » Tue Apr 12, 2005 3:07 pm
Went to 3 dealerships in Orlando, Fl and not one of them knew anything about this. They all said the same thing, have to wait for the TSB to be released.
2004 SLE Red/Gray Leather
MudGuards
TRD Air Filter
redsle
Postby ndoyank » Tue Apr 12, 2005 7:46 pm
Hearing all these problems with the 04 model im wondering if the 05 models still have these issues. I've been reading the past few posts about TSB's and I am noticing alot of shaking in the rear tray deck. I was wondering if anyone could pm me the pdf file, as I would like to get this fixed.
ALso,
if you have any other tsb send em my way.
Thanks
18' volks, TRD RSB, TRD FSTB, TRD springs, HID retrofit. Micheal T's Grille ..... Silver ICE
ndoyank
Postby Jackass-Jeff » Tue Apr 12, 2005 8:07 pm
TC004-03 is the TSB issued on the ES 330
I looked in the Solara department... nothing seen regarding the ECM shifting enhancement...
1GR-FE ftw!
Jackass-Jeff
Postby slingshot » Tue Apr 12, 2005 10:04 pm
ndoyank wrote:Hearing all these problems with the 04 model im wondering if the 05 models still have these issues. I've been reading the past few posts about TSB's and I am noticing alot of shaking in the rear tray deck. I was wondering if anyone could pm me the pdf file, as I would like to get this fixed.
ALso,
Thanks
I had noises in the rear deck and brought it in to the dealer. They put more insulation to fix it.
slingshot
Postby slingshot » Tue Apr 12, 2005 10:06 pm
Jackass-Jeff wrote:TC004-03 is the TSB issued on the ES 330
Doesn't the ES 330 share the same transmission with the Solara? It's practically a 4 door lux'ed up version of the Solara. I would think the Solara would benefit from the same TSB fix.
slingshot
Postby Jackass-Jeff » Tue Apr 12, 2005 10:17 pm
Same hardware, different software. The ES software is smoother than the Solara's... if they did the ES update on the Solara, then why buy an ES?
1GR-FE ftw!
Jackass-Jeff
Postby technole » Tue Apr 12, 2005 11:54 pm
There is supposed to be an update for all 3.3L 5-speed autos which would include the RX330, ES330, Solara V6, 2004-2005 Highlander V6, 2005 Camry V6...
technole
Postby Jackass-Jeff » Wed Apr 13, 2005 8:19 am
So you're gonna believe a shady online newspaper over a Lexus employee.
GG.
Eventually they will release the fix for the Toyota side... just because it's the same hardware doesn't mean it's the same software, as I previously stated.
The RX and ES software is TOTALLY different. Different shift points, different VVT-i phasing...
Load the RX software in your car and see ... it'll have more torque and less HP. VVT-i is an amazing tool.
The Toyota teams should have the Lexus programs loaded onto their bricks... tell them to load the RX program for you. I dare you. Worst case scenario, your ECM rejects the program and locks up. =P
The Toyota brick (seems) to allow you to reprogram everything that's electronically controlled in your car... so who needs a S-AFC... hehehehe
1GR-FE ftw!
Jackass-Jeff
Postby mattyboyl » Wed Apr 13, 2005 8:32 am
I'd be curious to see the results with a different program. I'm sure someone here has connections and get that done. I'd love to see before and after 1/4 mile times or even 0-60 times.
mattyboyl
Postby Jackass-Jeff » Wed Apr 13, 2005 10:02 am
bring me a solara... i have the TOYOTA test tool.
anyone willing to void a warranty and possibly lock up their $1200 ecu?
1GR-FE ftw!
Jackass-Jeff
