SolaraGuy.com • View topic - Owners with 20inch rims and lowered - FIXED
Postby Solara08861 » Mon Apr 25, 2005 1:54 pm
I took my car to the dealer because I was getting a noise from the rear of the car. They checked my car and they said that my rear tires are rubbing with the struts tower. Has anyone had that problem?
Solara08861
Postby Solara08861 » Mon Apr 25, 2005 3:04 pm
They did not rub untill I dropped the car.
Solara08861
Postby Solara08861 » Mon Apr 25, 2005 6:21 pm
They showed me its actually rubbing with the wishbone arm
Solara08861
Postby dvdchris45 » Mon Apr 25, 2005 7:32 pm
While its still on topic, what are the offset numbers for the tires/rims again?
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby R-TicFrost » Tue Apr 26, 2005 6:26 am
You are probably running too high of an offset, rim width and tire. I have 20x8.5 (+40 offset) wheels with 235/35/20 tires, lowered with TRD Springs. I have no rubbing at all with 3 people in the back.
R-TicFrost
Postby Solara08861 » Tue Apr 26, 2005 7:49 am
Do you have the TRD rear sway bar? if you do do u have set up on the top hole or the middle one?
Solara08861
Postby Solara08861 » Wed Apr 27, 2005 9:28 am
Problem has been fixed.
I took the car to my mechanic to check the niose, all it was the rear struts were comming loose from the top. He tigh them up and the car runs smooth now.
Solara08861
Postby JayDubz » Thu Apr 28, 2005 11:12 am
Funny.. what is the size and offset of wheels and tire mesaurements...
this was never answered... just curious..
2000 Galant... Mods in progress!!Image
http://www.cardomain.com/memberpage/350820/
JayDubz
Postby eparedes » Wed May 04, 2005 11:51 pm
check the width of ur rims, my buddy had 18's on his 2000 neon and was rubbing too. his strut evently broke then had it got it fixed , but anyways he found out that it was the width of the rims that cause it . if he would gotten a smaller width then it would of been ok...
eparedes
Postby BigPhizzle » Mon May 09, 2005 11:55 am
my car rubs like crazy. when im by myself its cool, but if i got 2 in the back it rubs and clicks all the time. What is a good way to fix this problem?
2000 Solara SEV6 - dropped - 18"rims - ground efx
- Big Phizzle -
BigPhizzle
Postby Solara08861 » Wed May 11, 2005 8:19 am
Not more issues since my mechanic took care of it.
Solara08861
