SolaraGuy.com • View topic - Dome light wire color?
Postby michaels artic frost » Tue Apr 26, 2005 5:58 am
I haven't had a chance to look into this much. Just thought I'd ask and see if anyone of you guys would know the dome light wire color. I need to know what harness it's located with (driver/passenger side).
I popped the dome light cover off and checked to see the wire color, but there's so many colors and harnesses on the passenger and driver side, don't really know which is which.
Thanks in advance,
Michael
Updated 06/01/12: Michael T's
Re: Dome light wire color?
Postby DocJohn » Tue Apr 26, 2005 8:28 am
michaels artic frost wrote:I haven't had a chance to look into this much. Just thought I'd ask and see if anyone of you guys would know the dome light wire color. I need to know what harness it's located with (driver/passenger side).
Thanks in advance,
Michael
Michael:
I'm on this one. I will check the wiring diagram manual tonight and post the answers.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby Down2TheC » Tue Apr 26, 2005 9:15 am
I'd check 4U but I just sent my new EWD to cp-e. Cool book tho. Thanks for the pub # DocJohn!
Down2TheC
Will update tonight
Postby michaels artic frost » Tue Apr 26, 2005 9:30 am
Thanks for the response guys. I believe I have located the wire and will test out my new customization tonight...muahahahhahahahahaaaaaaaa :drinking: :drinking: :drinking: :drinking:
-Michael
Postby boaclub923 » Tue Apr 26, 2005 11:46 am
u found the wires already?
man, i was ganan post up the pix,
i did something to my doom light wires b4...
well, i guess u don't need it now...
good luck on ur new mod~ ^^
boaclub923
Postby Willy7o2 » Tue Apr 26, 2005 12:55 pm
ehhh.... what are dome lights?
2004 Solara V6 SLE
TRD FSTB+RSB & Muffler
K&N High Flow Air Filter
Front GFX Lips
Mike T's Custom Grill Combo
Limo-Tint All Around
Willy7o2
Postby Down2TheC » Tue Apr 26, 2005 2:54 pm
watcha doing michael? Adding a disco ball? We want pics!
Down2TheC
Postby DocJohn » Tue Apr 26, 2005 4:57 pm
Looks like I'm too late but here it is anyway... According to the wiring diagram for the dome light:
the solid red wire is hot (+)
the white and black wire is ground (-) (“on”)
the green and red wire is the (“door”) switched ground (-)
The wires run from the dome light to the left (driver’s) side of the roof, then along the extreme left side of the roof (closet to the door), then down the left “A” pillar.
I hopes this helps. If you need more info, just let me know.
DocJohn
Dangit...it didn't work as I had planned.
Postby michaels artic frost » Wed Apr 27, 2005 4:40 am
Thanks for the help last night DocJohn. Unfortunately, going the route we discussed is not too safe as I found out from experience...heehee
Going to go with two 5 terminal relays and a switch so I can control it as well.
I'll keep you guys posted.
-M 8)
