SolaraGuy.com • View topic - taillight removal
taillight removal
taillight removal
Postby ndoyank » Mon May 16, 2005 12:52 am
Anyone know how to remove the the back taillights?
18' volks, TRD RSB, TRD FSTB, TRD springs, HID retrofit. Micheal T's Grille ..... Silver ICE
ndoyank
Postby sorkang724 » Tue May 17, 2005 5:17 pm
looks too hard....
sorkang724
Postby Aotoyota » Tue May 17, 2005 7:24 pm
i started but decided not to do it. gotta pull out the seat the unbolt the seats from the frame, then pull the rear pillar,
then then, the sides come off, both sides, where u will need to unbolt the seatbelt too and then the deck comes off after removing the snaps. i didnt think it was worth it in the end...
Aotoyota
Postby Kjk747 » Tue May 17, 2005 7:49 pm
I just broke mine and it's real easy! You have to remove the bolt for the cargo net first, then you open the preforated flap that you will see in the trunk. THere are 2 tabs for the electrical cable and there are 2 nut's you will have to remove below that. Done right? Nope the hardest part is trying to push the tail light out! There is a metal plug like thing that inserts into a plastic adapter in the trunk. You probably should try to push this tab out instead of pulling out the taillight because if your like me I pulled at the corner too much and broke the tail light even more. I did not care as I was replacing it anyway. Insertion is the opposite of removal. Good luck getting it flush again mine is almost at that same point but not exact. Hope that helps. Oh BTY dealer charged me 155.00 with tax for that whole assembly.
Kjk747
