SolaraGuy.com • View topic - Getting some caliper paint...
Postby dvdchris45 » Tue May 31, 2005 9:14 pm
So I ordered some VHT Brake caliper paint in Aluminum color. My question is this:
As far as spraying the paint goes, should I detach the calipers from the rotors to spray it (might get paint on the rotors) and if I do so, do I need to readjust bleed the brakes or anything of that sort?
Might be a noob question, but I'm picky when it comes to modding my ride and I dont wanna F it up.
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby PhreakdOut » Tue May 31, 2005 10:29 pm
It's best to remove the caliper from the rotor.
However, you do not need to disconnect it from the brake lines.
1) Remove the two bolts from the back side of the caliper.
2) Slide the caliper off the rotor. Remove the brake pads by pushing them out of their slots in the caliper. (Note which one is inboard and which is outboard.) Lay a couple thick towels over the disc and strut areas. (Newspapers are a pain so I sacrificed a couple shop towels instead.)
3) Keeping the brake line attached; degrease and thoroughly clean the caliper surface. Suspend the rotor by wire or coat hanger if needed.
4) Sand the caliper as much as possible to smooth the surface before painting. (Pick a grit at your own discretion. I used 80 grit then 150. However, since it's cast, the 150 really didn't do anything.) This helps prep the surface for better paint adheasion.
5) Do your first coat lightly. Let it dry for 15 - 30 minutes depending on humidity. (Apply in 70°F or higher ambient temp)
6) Keep applying coats allowing proper drying in between. (Relax and TAKE YOUR TIME.) It looks better after drying so don't be discouraged as you paint.
7) Press the caliper piston back into the caliper. (You can use a C-Clamp to do this, but I found it easy enough to do this by hand.) Assemble the pads back into the caliper. (Remember which one goes on the inside and which one goes on the outside? You should, unless you are replacing the pads.) Reattach the two caliper bolts and tighten. (I can't remeber the torque, but I know I applied a lot.) After assembly is completed all the way around, pump the brakes up to move the caliper pistons back to their proper positions.
8) Most importantly, take pictures and post them for your buddies on SolaraGuy.org.
Best of luck bro. Hope this helped.
Here's a pic of my caliper:
Postby HomeboyMI » Wed Jun 01, 2005 12:52 pm
I bought my paint (red) at Walmart for less than $5.00 a can. Only needed one can. I just took the wheels off and wrapped newspaper around the area I didn't want paint. It worked just fine. My calipers look just as good as the one in the picture above.
HomeboyMI
Postby bassthrive » Wed Jun 01, 2005 12:59 pm
Painted mine with silver engine enamel right on the car. I just used lots of masking tape and newspaper.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby HomeboyMI » Wed Jun 01, 2005 5:32 pm
Let me clarify; the paint that I bought at Walmart was "Caliper Paint". I wouldn't risk using any other because of the high heat caused by braking. They carry white, red, yellow and blue in the automobile paint section.
HomeboyMI
Postby alan8888 » Tue Jun 07, 2005 5:21 pm
how to make the trd....thing on there ?
alan8888
Postby Paladin06Greg » Tue Jun 07, 2005 5:40 pm
Yea, I been painting for years but no more. Check this out.
http://www.tuner01.com/
Paladin06Greg
Torqued Solara
Torqued Solara
Postby sorkang724 » Tue Jun 07, 2005 7:37 pm
damn those are HOT !
but damn ...they are $350 and the color ones are $235 !..i'll definitley purchase those when i get the money !
sorkang724
Postby DatSRBoi » Tue Jun 07, 2005 9:08 pm
How did you get the TRD thing on the brakes broh?
Postby ptorican-king » Tue Jun 07, 2005 10:18 pm
DatSRBoi wrote:How did you get the TRD thing on the brakes broh?
if i remember correctly is a sticker theres a post on the pciture , video section
LUIS
1999 SLE Green stock SOLARA
ptorican-king
Postby Down2TheC » Wed Jun 08, 2005 1:06 am
Paladin06Greg wrote:Yea, I been painting for years but no more. Check this out.
Awesome! Me want! Brushed Aluminum would be great with my ride.
Down2TheC
Postby dvdchris45 » Wed Jun 08, 2005 9:07 am
NICE. But I dunno about dropping $200+ for some brake color. Nice find nonetheless
dvdchris45
Postby Paladin06Greg » Wed Jun 08, 2005 9:11 am
Thanks for the comps but the credit goes out to another one of our SolaraGuy brothers.
dvdchris45 wrote:NICE. But I dunno about dropping $200+ for some brake color. Nice find nonetheless
Paladin06Greg
Torqued Solara
Torqued Solara
Postby PhreakdOut » Wed Jun 08, 2005 6:59 pm
LUIS
Hey there all. Been offline a few days.
Here's the original thread for regarding the TRD stickers on the Calipers. Enjoy!
http://solaraguy.org/viewtopic.php?t=17158&highlight=painted+calipers
