SolaraGuy.com • View topic - Warranty: Oil change
Postby Katherine » Wed Jun 15, 2005 11:52 am
Hi,
I got my second oil change done at a Valvoline place (I was on a road trip at the time, 800 miles from home, and realized I wouldn't make it back by the 3000 mile mark since the last oil change.. By the time I would get home, it would have been 4000 miles since the previous oil change. Maybe it would have been fine but I didn't want to chance it). I saved the paperwork, even though the Valvoline place didn't put the VIN in there.... I am just a little concerned that the dealership will give me a hard time next time I need warranty work. I know a lot of you do your own oil changes or get them done by someone other than Toyota... what is your experience with this? Thanks :)
2004 SLE V6
Cosmic Blue/Stone
Katherine
Postby Jai_Jai_Binks » Wed Jun 15, 2005 11:58 am
Dude, RELAX...as long as you keep your record of an oil change, toyota will honor their warranty. Only time this could become an issue is when the valvoline place did something they weren't supposed to like over tight and strip the oildrain plug! As long as you do your oil changes and timely other maint its all good!
Postby mattyboyl » Thu Jun 16, 2005 8:24 am
Read the manual. Toyota suggests every 5K miles, not 3K. So according to waranty standards, your well under the mark.
mattyboyl
Postby Katherine » Thu Jun 16, 2005 10:55 am
I thought it was 5000 miles until the first oil change, and then every 3000 after that? The dealership had me down for 3000 miles after my first one (at 4500 miles). I gotta look at the manual. If so, then I wasted my money. Thanks
2004 SLE V6
Cosmic Blue/Stone
Katherine
Postby mattyboyl » Thu Jun 16, 2005 11:02 am
Stealerships want to make money. There is no harm coming in every 3,000, but is unessary according to the manual. :D
mattyboyl
Postby kgzero1 » Thu Jun 16, 2005 11:24 am
Every 5,000 miles.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
http://www.cardomain.com/ride/850364
http://www.cardomain.com/ride/2055035
kgzero1
Postby so-cal_sol » Thu Jun 16, 2005 11:43 am
kgzero1 wrote:Every 5,000 miles.
it is every 5k miles, i've got a little bit less than 3,000 on mine but the sticker in the window says "next oil change 5,000" they're supposed to be better engines that can last longer between oil changes. also my sister has a BMW and that one's oil change is every 15,000 miles. (yes i said 15,000 miles)
2005 lunar mist metallic se V6
Trenz Grill
Eclipse 2454 HU
TRD springs *DROPT BY MILT*
so-cal_sol
Postby Katherine » Thu Jun 16, 2005 1:05 pm
Wow... 15K miles :o I'm so dumb, I should have looked in the manual, I had it right there in the glove box. Duh. :oops: Anyway thanks everyone for the info.
2004 SLE V6
Cosmic Blue/Stone
Katherine
Postby kgzero1 » Thu Jun 16, 2005 2:56 pm
The manual also says you can go up to 7500 miles. I have alsways done it every 5k though.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
kgzero1
Postby so-cal_sol » Thu Jun 16, 2005 4:17 pm
Katherine wrote:Wow... 15K miles :o I'm so dumb, I should have looked in the manual, I had it right there in the glove box. Duh. :oops: Anyway thanks everyone for the info.
15k miles on a BMW not a toyota
Trenz Grill
Eclipse 2454 HU
so-cal_sol
Postby dawp » Sat Jun 18, 2005 11:49 pm
bmw most likely uses sythetic and not conventional oil so y get a longer time between changes.
dawp
Postby Hunter_alexander » Mon Jun 20, 2005 4:59 am
Wow you guys and gals running your cars to 5k without changing oil are brave. Sorry, but take a look at your oil at 3k. It is dirty. Better engines or not, I would never risk leaving my oil go to 5k or worse yet 7500.
2004 Lunar Mist Metallic SLE V6 Fully optioned (well minus the navi system)
Hunter_alexander
Postby RichD978 » Mon Jun 20, 2005 5:44 am
i do it at 6,500 - 7,500 miles... cant afford doing it every 3K when its mobil 1 and k & n oil filter
RichD978
Postby JayDubz » Mon Jun 20, 2005 8:19 am
nissan 350z is every 15k miles too.. ive heard that some newer benzes are lift time oilchanges.. which meaning u dont ever have to get one....
i was reading about it some time ago.. they have some special thing that recycles the oil and keeps it clean.. anyone ever heard of this??
just currious if what i heard was true or not... 8)
2000 Galant... Mods in progress!!Image
http://www.cardomain.com/memberpage/350820/
JayDubz
Postby Katherine » Mon Jun 20, 2005 8:19 am
I know... I was just saying "wow" to the 15K mile oil change for the BMW :)
2004 SLE V6
Cosmic Blue/Stone
Katherine
