SolaraGuy.com • View topic - UPDATED I have made a list of all the TSB's for 2nd gens
Postby Hunter_alexander » Mon Jun 20, 2005 7:41 am
Here are all the links for the second gen solara's for the TSB's. Hope this helps someone out there who has questions.
ECM reset memory function
http://www.alldata.com/tsb/Toyota/1103529600000_1105516800000_TC002R-03/21.html
Mil On DTC p0604, p0606, p0607
http://www.alldata.com/tsb/Toyota/1103616000000_1105516800000_EG051-04/511.html
Lev 2 evap system check
http://www.alldata.com/tsb/Toyota/1104998400000_1105516800000_EG048R-04/1.html
tonneau cover replacement
http://www.alldata.com/tsb/Toyota/1107417600000_1108972800000_BO002-05/1.html
vehicle pull drift fix
http://www.alldata.com/tsb/Toyota/1107504000000_1110182400000_ST002R-04/21.html
MIL on dtc p0031, p0051, p2238, p2241
http://www.alldata.com/tsb/Toyota/1108627200000_1110182400000_EG008-05/81.html
MIL ON dtc p0346
http://www.alldata.com/tsb/Toyota/1108713600000_1110182400000_EG010-05/101.html
Passenger airbag indicator lamp
http://www.alldata.com/tsb/Toyota/1112684400000_1113548400000_EL005-05/551.html
Tire Pressure Warning System initialization procedure clarification
http://www.alldata.com/tsb/Toyota/1112684400000_1113548400000_PG004R-04/41.html
Tick Noise from front speaker at mirror base
http://www.alldata.com/tsb/Toyota/1112770800000_1113548400000_NV003-05/351.html
Moonroof Grinding Groaning noise
http://www.alldata.com/tsb/Toyota/1113202800000_1115103600000_NV004-05/41.html
Occupant Classification system DTC B1785
http://www.alldata.com/tsb/Toyota/1116831600000_1118214000000_EL009-05/9051.html
AC light flashing magnetic clutch relay
http://www.alldata.com/tsb/Toyota/1117782000000_1118214000000_EL011-05/11.html
Entering vin during ECM (PCM) replacement and or DTC P0630
http://www.alldata.com/tsb/Toyota/1106553600000_1108713600000_EG045R-04/451.html
Now we have a nice easy to click place to find out TSB's just for our second gens.
Last edited by Hunter_alexander on Wed Jun 29, 2005 10:24 am, edited 2 times in total.
2004 Lunar Mist Metallic SLE V6 Fully optioned (well minus the navi system)
Hunter_alexander
Postby JayDubz » Mon Jun 20, 2005 8:16 am
For those that dont have high speed u should have put a label for each link.. but ah well.. :drinking:
2000 Galant... Mods in progress!!Image
http://www.cardomain.com/memberpage/350820/
JayDubz
Postby MrMikeL » Mon Jun 20, 2005 9:53 am
Did anyone catch this one:
http://www.alldata.com/tsb/Toyota/1117782000000_1118214000000_TC003-05/index.html
Isn't this the lag issue? This was issued 6/3/05. Anyone have this service done yet?
MrMikeL
Postby PhreakdOut » Mon Jun 20, 2005 10:17 am
MrMikeL wrote:Did anyone catch this one:
You are my hero!! (Ahem ... I don't mean that in a queer sort of way.)
I've made an appointment with the dealer to take it in on Thursday. I hope this works.
Just in case, I'm going to reverse DocJohn's intake door trick back to the original setup. That will take a whole 9.5 seconds. (I don't want any issues from Toyota regarding the cause of the lag)
Postby PhreakdOut » Mon Jun 20, 2005 11:40 am
Dang it! I missed this from my last post.
The bulletin specifically calls out '04-05 Camry (3MZ-FE, 5-Speed A/T) but not Solara. While we all know this should be the same, will the dealers apply this TSB to the Gen 2 Solara?
Anyone have some thoughts on this? My dealer does not want to perform this on a Solara without the TSB calling for that car.
Postby MrMikeL » Mon Jun 20, 2005 3:01 pm
Can the dealer check up the line to see if it is the same? I mean, isn't the drive train identical between Camry and SOlara??
MrMikeL
Postby bob015 » Tue Jun 21, 2005 1:41 pm
I just took my car in and asked if they had a T.S.B. for my Solara they said yes # TC006-05 and they would performe E.C.U. upgrade / recalibration for the hesitation problem. I have not checked to see if it corrected it or not.
bob015
Postby GuavazoEX » Tue Jun 21, 2005 6:32 pm
hi, so i'm the first time on these kind of problem. i boughtmy solara last year june, how do i check if i need to bring by car back to dealer or, i can jsut to go dealer and ask if there is any TBS for my car? will they charge me for it or it's free?
Solara SE V6 Oceanus Pearl
20% tint all around~
K&N Air-Filter installed
GuavazoEX
Postby Shoe » Tue Jun 21, 2005 8:30 pm
this is a very important thread which will get many repeat visits
many people will also get directed to this list
I think a special place should be made for this thread either a copy of it in the FAQ or make it a sticky. So it can be easily found by all.
oh thanks for the research your time was much appreciated
shoe
Shoe
Postby Hunter_alexander » Wed Jun 22, 2005 5:13 am
NO prob. I figured that if I had questions on TSB's then others probably do also. Nice to have everything in one place instead of searching all the threads for it.
Hunter_alexander
Postby MikeATL » Wed Jun 22, 2005 6:32 am
can someone post the TC006-05 TSB?
MikeATL
Postby Down2TheC » Wed Jun 22, 2005 10:15 am
Nice avatar, fishbulb.
Down2TheC
Postby MikeATL » Wed Jun 22, 2005 10:33 am
Mista Spakaru!
Arigatou.
MikeATL
Postby Hunter_alexander » Wed Jun 29, 2005 10:26 am
If you look at the top, I have labeled each one. I am still waiting for the internet link for the Lag problem, and I will then post that one to the above links.
Hunter_alexander
