SolaraGuy.com • View topic - TSB list
TSB list
TSB list
Postby Turbosolara » Tue Jun 28, 2005 9:24 pm
Can someone compile a list of the TSB number and names? I want to take my gf's gen2 to get them fix. Also Mod please make it sticky, thanks
Postby DocJohn » Wed Jun 29, 2005 5:38 am
Here they are. I have the PDF's for all of these (except TC006-05 for now). It would be nice if there was a place on this site they could be filed so members could download them as needed.
PA006-03 PAINT COLORS 2003-07-21
BO024-03 SEAT BELT EXTENDER 2003-12-09
BO025-03 WATER LEAK AT COWL - WATER ON FRONT FLOOR 2003-12-11
PD005-03 PRE-DELIVERY SERVICE (PDS) 2004-08-04
PD006-03 PRE-DELIVERY SERVICE (PDS) INFORMATION 2004-08-04
AU002-04 POOR RADIO RECEPTION 2004-02-23
BR001-04 ZERO POINT CALIBRATION REQUIRED WHEN REPLACING VEHICLE STABILITY CONTROL OR STEERING RELATED PARTS 2004-02-04
EL002-04 OCCUPANT CLASSIFICATION SYSTEM INITIALIZATION 2004-02-26
ST002-04 VEHICLE PULL IMPROVEMENT PROCEDURE 2004-02-04
EG005-94 MIL ON - ENGINE MISFIRE DTC P0300/P0301/P0302/P0303/P0304/P0305/P0306 2004-04-12
EG007-04 MIL ON - DTC P0010 OR P0020 2004-04-16
TC002-04 U151E/U151F TRANSMISSION SOLENOID IDENTIFICATION 2004-04-06
TC004-04 MIL ON - DTC P0748/P0798/P0985/P0986 2004-04-16
EG014-04 EXCESSIVE SULFUR DIOXIDE ODOR 2004-05-24
EL002-04R OCCUPANT CLASSIFICATION SYSTEM INITIALIZATION (DTC B1150 AND B1650) - REVISED 2004-05-11
PG003-04 REPAIR MANUAL CORRECTIONS INDEX 2004-05-18
BO012-04 TONNEAU COVER IMPROVEMENT 2004-06-08
NV007-04 REAR PACKAGE TRAY RATTLE 2004-06-02
NV008-04R MOON ROOF (SLIDING ROOF) RUBBING / SHUDDERING NOISE - REVISED 2004-06-21
NV008-04 MOON ROOF (SLIDING ROOF)RUBBING / SHUDDERING NOISE 2004-06-18
BO030-1R WINDSHIELD WIPER BLADE MAINTENANCE AND CLEANING - REVISED 2004-07-13
EG014-04R EXCESSIVE SULFUR DIOXIDE ODOR - REVISED 2004-07-29
PD017-04 WHEEL FILM FOR BRAKE ROTOR RUST PREVENTION 2004-07-16
SU001-04 REAR SUSPENSION NOISE 2004-07-27
EG029-04 MIL ON, DTC P0171 AND/OR P0174 - ENGINE RUNNING LEAN 2004-08-04
EG033-04 MIL ON, DTC P0031 AND/OR P2238 2004-08-23
EL009-04 POWER WINDOW/ROOF INITIALIZATION PROCEDURES 2004-08-10
PG004-04 TIRE PRESSURE WARNING SYSTEM INITIALIZATION PROCEDURE CLARIFICATION 2004-08-27
TC005-04 U240E / U241E TRANSAXLE SOLENOID IDENTIFICATION 2004-08-26
EG037-04 ENGINE BANK 1 AND BANK 2 A/F AND O2 SENSOR IDENTIFICATION 2004-09-03
EG040-04 ACCESSORY DRIVE BELT SQUEAL / BELT TENSIONER RATTLE 2004-09-08
NV009-04 CONVERTIBLE TOP WIND NOISE IMPROVEMENT 2004-09-20
PA002-02R PAINT STAINS UNDER RAPGARD - REVISED 2004-09-09
PD005-03R PRE-DELIVERY SERVICE (PDS) - REVISED 2004-10-11
PG005-04 TIRE PRESSURE WARNING SYSTEM INFORMATION AND RE-INITIALIZATION 2004-10-07
EG048-04 REPAIR MANUAL SUPPLEMENT: LEV II EVAP SYSTEM CHECK - DTC P0441/P0442/P0446/P0451/P0452/P0453/P0455/P0456 2004-11-12
PA005-04 IRON PARTICLE RUST CONTAMINATION REPAIR 2004-11-16
PG004-04R TIRE PRESSURE WARNING SYSTEM INITIALIZATION PROCEDURE CLARIFICATION - REVISED 2004-11-09
AC009-04 SENSOR INSPECTION FOR AIR CONDITIONING SYSTEM 2004-12-16
BO022-04 SEAT BELT EXTENDER 2004-12-09
EG051-04 MIL ON - DTC P0604/P0606 AND/OR P0607 2004-12-21
PA005-04R IRON PARTICLE RUST CONTAMINATION REPAIR - REVISED 2004-12-16
PD005-03R PRE-DELIVERY SERVICE - REVISED 2004-12-09
ST002-04 VEHICLE PULL/DRIFT IMPROVEMENT PROCEDURE - REVISED 2004-12-02
TC002-03R ECM RESET MEMORY FUNCTION AFTER A/T REPLACEMENT OR REPAIRS - REVISED 2004-12-20
EG048-04R LEV II EVAP SYSTEM CHECK - DTC P0441/P0442/P0446/P0451/P0452/P0453/P0455/P0456 - S/M REVISION - REVISED 2005-01-06
BO002-05 TONNEAU COVER REPLACEMENT 2005-02-03
EG008-05 MIL ON, DTC P0031/P0051/P2238 AND/OR P2241 2005-02-17
EG010-05 MIL ON - DTC P0346 2005-02-18
PA003-02 REFINISHING REPLACEMENT BUMPER COVERS - REVISED 2005-02-14
ST002-04R VEHICLE PULL/DRIFT IMPROVEMENT PROCEDURE - REVISED 2005-02-16
EG014-05 RADIATOR CAP INSPECTION 2005-03-28
TC006-05 ECM CALIBRATION: SHIFT FEELING ENHANCEMENT 2005-06-03
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby Shoe » Wed Jun 29, 2005 6:42 am
there is a list here
http://www.solaraguy.org/viewtopic.php?t=18129
but the thread wasnt made a sticky or added to the FAQ and i still think it should be as its an IMPORTANT thread
the links should also be labeled as someone else noted
shoe
Shoe
Postby Hunter_alexander » Wed Jun 29, 2005 10:09 am
OK , I will label the links. :)
2004 Lunar Mist Metallic SLE V6 Fully optioned (well minus the navi system)
Hunter_alexander
Postby Turbosolara » Wed Jun 29, 2005 11:16 pm
Holy...thats alot of TSBs...
so how does it work anyway?
thanks for response
Postby DocJohn » Fri Jul 01, 2005 6:26 am
Turbosolara wrote:Holy...thats alot of TSBs...
thanks for response
I'm not sure I understand what you mean by "how does it work anyway?". I have PDF's for all these TSB's but no where to post them for download.
Alldata.com has most of the important TSB's listed here uploaded as GIF's and Hunter_alexander has made a post with links to them.
See: http://www.solaraguy.org/viewtopic.php?t=18129
DocJohn
Postby Hunter_alexander » Fri Jul 01, 2005 7:19 am
Here, since this post has become a sticky, I will post all the links I have for the website TSB's on here. That way it is all in one place.
Nice and neat. :)
ECM reset memory function
http://www.alldata.com/tsb/Toyota/1103529600000_1105516800000_TC002R-03/21.html
Mil On DTC p0604, p0606, p0607
http://www.alldata.com/tsb/Toyota/1103616000000_1105516800000_EG051-04/511.html
Lev 2 evap system check
http://www.alldata.com/tsb/Toyota/1104998400000_1105516800000_EG048R-04/1.html
tonneau cover replacement
http://www.alldata.com/tsb/Toyota/1107417600000_1108972800000_BO002-05/1.html
vehicle pull drift fix
http://www.alldata.com/tsb/Toyota/1107504000000_1110182400000_ST002R-04/21.html
MIL on dtc p0031, p0051, p2238, p2241
http://www.alldata.com/tsb/Toyota/1108627200000_1110182400000_EG008-05/81.html
MIL ON dtc p0346
http://www.alldata.com/tsb/Toyota/1108713600000_1110182400000_EG010-05/101.html
Passenger airbag indicator lamp
http://www.alldata.com/tsb/Toyota/1112684400000_1113548400000_EL005-05/551.html
Tire Pressure Warning System initialization procedure clarification
http://www.alldata.com/tsb/Toyota/1112684400000_1113548400000_PG004R-04/41.html
Tick Noise from front speaker at mirror base
http://www.alldata.com/tsb/Toyota/1112770800000_1113548400000_NV003-05/351.html
Moonroof Grinding Groaning noise
http://www.alldata.com/tsb/Toyota/1113202800000_1115103600000_NV004-05/41.html
Occupant Classification system DTC B1785
http://www.alldata.com/tsb/Toyota/1116831600000_1118214000000_EL009-05/9051.html
AC light flashing magnetic clutch relay
http://www.alldata.com/tsb/Toyota/1117782000000_1118214000000_EL011-05/11.html
Entering vin during ECM (PCM) replacement and or DTC P0630
http://www.alldata.com/tsb/Toyota/1106553600000_1108713600000_EG045R-04/451.html
Hunter_alexander
Postby Turbosolara » Fri Jul 01, 2005 12:56 pm
I mean do you just bring the car into dealer and show them the TSB number? and they will fix it for our for free?
Postby slingshot » Fri Jul 01, 2005 2:36 pm
Turbosolara wrote:I mean do you just bring the car into dealer and show them the TSB number? and they will fix it for our for free?
You have to know what things the TSB fixes and complain about them to the dealer. If you then show the TSB, they should fix it for free. But you do have to complain that you have the issues in them.
slingshot
Rear THUMPING TSB
Postby joebxr » Wed Mar 15, 2006 5:39 pm
Read several threads about rear thumping that has been driving me crazy. Looks like Toyota finally got onboard and has a TSB to fix.
Suspension - Rear Suspension Thumping Noise On Bumps
http://www.alldata.com/tsb/Toyota/1140508800000_1141718400000_SU002-06/261.html
'06 Solara SLE V6
Arctic Frost/Dark Stone Grey
TRENZ Upper and Lower Billet Grilles
American Racng CASINO Polished wheels
SIRIUS Satellite Radio
joebxr
Postby PXLpainter » Mon Aug 07, 2006 6:22 pm
Step 1) Locate the TSB you want taken care of, and study the section where it states what the customer might be complaining about.
Step 2) Make appointment with dealer for repairs and just tell them the complaint (as stated on the TSB).
Step 3) Tell service writer when you drop off your car the same complaint as stated on the TSB, then show them the print-out of the TSB and tell them you found this online.
If the TSB is for your model/year of car, then they HAVE to honor it if you state the issue. If the dealer does not honor it, then call Regional Cust Svc and open up a claim. They will help you resolve it quickly!
Postby SolaraDon » Sat Sep 02, 2006 12:11 pm
Sorry if its somewhere on the site but I couldn't find it.
TSB for noises in steering shaft (clunk, pop, knock) of 2004-2006 Solara (and 03-06 Camry and 04-05 Highlander) is http://www.alldata.com/tsb/Toyota/11533 ... 06/11.html
I my case however it was the lower shaft with excessive play, not the intermediate shaft. Dealer said they've seen a problem with those but usually it is the intermediate shaft as in the TSB.
TSB is ST001-06 (revised), February 16, 2006.
SolaraDon
Postby SolaraDon » Mon Sep 25, 2006 9:25 am
And another one that covers our cars: "Front Seat Squeak Noise" for '04-'07 Toyotas and Scions. I have to try this one because I have a seat squeak that's driving me nuts.
http://www.alldata.com/tsb/Toyota/11483 ... index.html
TSB is NV004-06, issued May 23, 2006.
SolaraDon
Postby shierj » Thu Sep 28, 2006 1:06 pm
Does anyone have a link to tsb nv008-04 or tc006-05. After the trans recalibration I am still not happy with the way it shifts. Anyone know if tc006-05 will help.
shierj
Postby sgunitkc » Sun Jan 07, 2007 9:56 pm
Does anybody have the copy of the TSBs for these? I checked the tsb list and everything and these weren't on our site.
EG040-04 ACCESSORY DRIVE BELT SQUEAL/ BELT TENSIONER RATTLE
NV004-06 FRONT SEAT SQUEAK NOISE
PG011-05 FUEL INJECTOR CLEANING (REVISED)
ST001-06 STEERING INTERMEDIATE SHAFT NOISE
Thank you so much in advance.
sgunitkc
Users browsing this forum: Google [Bot] and 3 guests
