SolaraGuy.com • View topic - dealer refused lag tsb
Postby dirtybird_1 » Fri Jul 08, 2005 8:52 am
took my se sport to the dealer this morning about the lag issue and when i spoke to them they told me they had not gotten anything. i then told them about the tsb that was out and he looked it up on his computer and then told me that it is not intended for the 4cyl engine, only the 6cyl. for some reason i feel as if i am getting jerked around but is this true? i hope not because i do have a noticable lag and really want this issue resolved. any help greatly appreciated.
2004 Solara SE Arctic Frost
15% tint
Polk Audio DB212 12" subs x2
Kicker KX600.1 Amp
Infinity refrence 6x9 all around
Colgan Custom Bra
http://photobucket.com/albums/b82/mikeflaman
dirtybird_1
Postby technole » Fri Jul 08, 2005 8:58 am
its only for the 3.3L V6. There is no issue with the 4cyl.
The 4cyl has a 4-speed transmission, whereas the issue is for the 5-speed which is in the 04-05 Solara V6s.
2004 Solara V6 SLE w/XM Satellite Radio
technole
Postby MrMikeL » Fri Jul 08, 2005 1:05 pm
The solution is for the 3.3L 6 cyl engines with ECM only. Not for your 2.4L 4 cyl engine.
MrMikeL
Postby ~Spadwaller~ » Fri Jul 08, 2005 1:24 pm
--1LOKEDOUTSLE-- wrote:Your lag problem is that you have a 4 banger!!!!!!!!!!
hahhahahaaha :lol:
~Spadwaller~
Postby qhoc0010 » Fri Jul 08, 2005 3:18 pm
So did anyone successfually had dealer to fix the lag problem on 5 spd v-6?
qhoc0010
Postby slingshot » Fri Jul 08, 2005 3:29 pm
qhoc0010 wrote:So did anyone successfually had dealer to fix the lag problem on 5 spd v-6?
Yes, all of us that have gone have been successful. It is a 100% successful fix.
slingshot
Postby cklinh » Fri Jul 08, 2005 3:38 pm
Except me.
I went in for the TSB... it was applied... still lags...
I called back, and the guy told me to drive it a bit more, and if it still lags, take it back and they'll look at it again.
cklinh
Postby MrMikeL » Fri Jul 08, 2005 3:42 pm
cklinh, I bet they didn't even do anything to it in hopes of saving 2 hours worth of warranty work. Find a different dealer if possible.
MrMikeL
Postby silversurfer220 » Fri Jul 08, 2005 3:45 pm
Nope- My dealership refuses to touch my car and they told me that as long as the car drives, they are not going to reprogram it. Its been in 2 times, with 2 long excuses written on the service document.
silversurfer220
Postby cklinh » Fri Jul 08, 2005 4:37 pm
MrMikeL wrote:cklinh, I bet they didn't even do anything to it in hopes of saving 2 hours worth of warranty work. Find a different dealer if possible.
I called in to make sure if it was done...
got verification from two people... but I'll give it another week or so before calling in again...
cklinh
Postby slingshot » Fri Jul 08, 2005 7:39 pm
silversurfer220 wrote:Nope- My dealership refuses to touch my car and they told me that as long as the car drives, they are not going to reprogram it. Its been in 2 times, with 2 long excuses written on the service document.
Definitely go to another dealership and say you have the problems that are listed in the TSB. THEN mention the TSB and say you would like to have it done to fix your problems.
slingshot
Postby slingshot » Fri Jul 08, 2005 7:40 pm
Very strange as this is the first account we've heard here of no change in performance. I'm still thinking it wasn't even done. Can you spin your tires starting out easily? What lag effects are you seeing?
slingshot
Postby cklinh » Fri Jul 08, 2005 10:49 pm
Spin tires starting slowly? Don't believe so... as for what I'm seeing,
at or around the 20 mph range, when I try to accelerate, there's a very noticeable delay of me actually feeling anything... and when I do go, I jerk forward... I haven't driven in "D" for a while (ever since one of the threads suggested to leave it at "S-5") so I don't know if this is normal... it also happens on or around 40 mph...
cklinh
Postby technole » Sat Jul 09, 2005 3:41 am
they might not have done the tsb correctly, maybe they didn't remove the ecm fuse when they were doing so.
technole
